Results 1 to 10 of 17
Thread: Aquarium Stand?
    Rochester, New York
    22
    Aquarium Stand?
    Hi all!
    Just wondering if anyone has a good plan for a simple and quick aquarium stand? My son is buying a 29 gallon high tank (29H I think it's called), and wants something that we can do before he goes home after Christmas break . Do you know of any websites I could use? Thanks in advance for any help you can lend!
    Google turned up a bunch of plans.
    http://www.google.com/search?sourcei...aquarium+stand
    Rochester, New York
    22
    Don, thanks for the reply. My son and I went through the majority of sites listed in your search, however we are still looking for a simple 29H stand. The ones listed didn't always have very detailed plans. The search continues....
    The Heart of Dixie
    4,268
    I have never seen any detailed plans for a good stand*. Best bet is find something you like and alter the dimension to suit. There are really only two critical factors in a stand.
    • The top must be flat! (Unless you like water on the floor)
    • The stand can't rack or twist.
    Other than those two there is not much else to worry about.
    * Good meaning not built from 2x4's to support the weight
    Rochester, New York
    22
    Thanks Jeff, but what do you mean by "Good meaning not built from 2x4's to support the weight."? Almost all the plans I've seen so far list 2x4's as the main ingredient for the grid that supports the top and bottom (like joists under a floor), then it gives various methods of enclosing the 2x4 frame. Do you mean I should go heavier (4x4's)? Thanks.
    Northville, MI
    507
    Not a plan but this linky has a few pics of the stand I made for my 75g tank. It is made with 3/4" material, frame and panel. That will be plenty strong for your tank size.
    Jim
    The Heart of Dixie
    4,268
    Sorry Tom, I just get so annoyed at the 2x4's. I should have explained, they are WAY overkill! Frame and panel (Like Jims), 1/2 plywood box, etc are strong enough to support a car. So don't stress over that part. Just build a good rigid box and you will be fine. As long as it doesn't rack, that is the only real concern. Any movement and it could fail. Compress failure from the weight of the tank is not an issue. Look at any commercial stand and you will see than are very light weight construction. Never seen a 2x in one.
    I have plans for a 120 gallon that will be open on 3 sides as a room divider. The stand has to look good as it is focal point. It will most likely be frame and panel construction. Haven't really sat down to design it. But IT WILL NOT have a 2x4 frame, that I am sure of.
    Custom built boats and Kits
    30,223
    So Jeff...how do you feel about using 2x4s for the frame? [ducks and runs...]
    Tom, are you looking for something that looks nice, or something quick and rugged for a college dorm room?
    15,811
    Been there and done that
    Like Jeff and others are saying, if you build it out of 1/2" plywood and have a solid top, bottom sides and back, with something like a face frame on the front, just to make the doors easier to hang, and to cover the edges of the plywood, you will be plenty strong. If you are REALLY concerned, (after all, 29 gallons of water would make a mess) then put a center panel in side the is basically a third side, but in the middle, that way you could put shelves on one side and a large open space on the other.
    I think you will get the best support for the unit if you build it so the sides of the tank sit almost directly above the sides of the cabinet, but it can also be a bit wider and you can put an edging on it to cover up the bottom corner of the tank.
    Good luck, take pics, we will be waiting to see what you come up with.
    Vancouver, B.C. Canada
    2
    more tank suggestions
    28 gallon tank will weigh in at...
    .280 pounds of water, gravel or whatever other substrate, and the aquarium itself...
    so about 400 pounds
    Oh and if it falls over you will have about 13mm of water covering the entire floor of a 10' x 10' room...thats if the room doesn't leak (and it will)
    I have built a few myself (from crude to pretty) and here are a few extra suggestions.
    A basic box like Stuart is suggesting will work great...it will give you some storage space underneath. You can also build a matching cover for the top if you have the time.
    Note that Jim's 75 gallon tank stand sits directly on the floor...just think what that whole unit must weigh? Don't put legs under it...that way the weight is distributed over the entire area not just 4 small points.
    And I left a space out of the back at the height of the wall sockets...often you locate the tank infront of a wall socket so you can hide all the wires in the bottom box. And once you set it in place it is very hard (and risky) to move if it is full of water. So that way if you have to place the stand in front of a socket ( or telephone or cable outlet) you can still access the socket.
    Good luck
  1. Cherry Aquarium Stand
    By Joe Acquisto in forum Flatwork Project Showcase
    Last Post: 02-23-2015, 01:57 AM
  2. Aquarium stand design
    By John Hemenway in forum Designs, Plans and Sketches
    Last Post: 01-20-2012, 11:43 PM
  3. Aquarium stand
    By Drew Watson in forum Flatwork Project Showcase
    Last Post: 09-13-2010, 10:26 AM
  4. Aquarium Stand
    By Mike Forsman in forum Flatwork Project Showcase
    Last Post: 03-09-2008, 03:26 PM
  5. Aquarium stand for my son.
    By Tom Pritchard in forum Flatwork Project Showcase
    Last Post: 03-04-2007, 11:03 PM
