Results 1 to 8 of 8
Thread: Craftsman Professional Model Table Saw
    Dec 2008
    Portland, Oregon
    1,898
    I have a Craftsman Professional Model Table Saw and I really like the saw it was easy to set up and works very well.
    The only problem I have is that the arbor is short. A 1/2" dado blade is about the maximum I can put on it.
    Does anyone know if there is a replacement arbor that has a longer threaded portion?
    Thanks for your time.
    Dan Mooney
    Rochester
    846
    Hi Dan, and welcome. Are you leaving the arbor washer off the arbor when you stack your dado set? Leaving the washer off is a common practice that's recommended by several manufacturers including Freud. As long as the nut is fully seated, it's a safe practice that allows a few more chippers to be added.
    HTH
    Got Wood?
    Dec 2008
    Portland, Oregon
    1,898
    Re:Craftsman Professional Model Table Saw
    Thanks for reply Scott, I tried your suggestion today and it worked beautiful!
    My eternal Gratitude!!
    Dan
    30,008
    Quote Originally Posted by Daan Mooney View Post
    Dan
    Of course, that's gonna cost you some pics of what your building. We like pictures around here.
    Welcome aboard, Dan. I'll echo Scott's advice...a lot of contractor saws have shorter arbors, and as he said, many manufacturers recommend leaving the washer off. It is important to get the nut all the way onto the threads.
    That's right! Scott's wizardry doesn't come cheap, we like pictures . FWIW, I leave the washer off my Freud stack for wider cuts as well.
    Jan 2009
    I live in Denton, Texas and ranched at Schulenburg, Texas.
    116
    Craftman Pro Table Saw
    I had your problem on both of my Craftsman saws (one is very old, 50s the other is very late 90s). I make a point to thread the nut on with the flat side toward the blade and it works very well with all three stacked dados and my Excaliber.
    Ray Gerdes
    I have a Dayton (Grainger) 10 TS, the company that make them for Grainger supplied them to Sears at one point. Check and see if your arbor has a recessed hex hole in the end of it. If so there is a dado arbor that is longer. I ran 2 sets of dado blades, with a 1/2" spacer between them. The set was used to make bridle joints on my 12 bar stools, 48 perfect cuts. I'd like to have a PM, but they don't have the longer arbor, and I don't have room for 2 TS's so I'll hang on to my Dayton.
    Attached Thumbnails Attached Thumbnails dado stack.jpg   joint cut.jpg   joint.jpg   bar stool.jpg
    Rochester
    846
    Can I pass "Go" and collect my $200 now?
    Got Wood?
  1. Craftsman Verriable Speed Model 351.217150
    By John Ledrich in forum General Woodturning Q&A
    Last Post: 05-29-2013, 12:00 AM
  2. Craftsman Table Saw - Model 113.27520
    By james f beck in forum General Woodworking Q&A
    Last Post: 02-23-2012, 11:33 AM
  3. Craftsman Model 351.217150 Lathe's Variable speed control broke
    By Dimitri Schreiber in forum New Tools
    Last Post: 08-13-2010, 09:42 PM
  4. Craftsman Table Saw model# 113.299410 in Indiana
    By Tom Baugues in forum Old Ads
    Last Post: 08-17-2009, 09:22 PM
  5. FS: Craftsman 10" Table Saw
    By Mike Hall in forum Old Ads
    Last Post: 06-04-2007, 03:59 PM
