Results 1 to 10 of 11
Thread: ok whats the trick?
    17,515
    ok whats the trick?
    to making outside corner that appears to be full size, i used two 2"styles cut the 45's lengthwize, here's the main question, how do you attempt at clamping the two pieces together? they seem to slide just abit to much and the flats arent quite where they usually are in normal glue up i didnt want to cheat and use any nails,, but after my first attemp i did pick up the pinner. but i didnt load it.. so if it isnt top secret i sure could use some advice
    Charlotte, NC
    1,487
    Lots O caulk!
    Seriously, I am assuming you are talking about crown mouldng? I have usually tried compensating for the alignment issue with the cut as best as possible and pin it with a brad. I know some use biscuits in the joint. Outside that, I probably can't help much so I'll be waiting to see what the others recommend.
    535
    Spline
    If I read you right. I've used biskits too, but recommend the spline because its easier for me to spell
    If ya want to get real tricky, cut both sides out of the same board, with the mitered edges on either side of the rip cut. The grain wraps around the corner and looks really good. The face grain on two sides at 90 degrees is a tip off to the woodworker, but it will really fool everyone else.
    Oh yeah, clamps, lots of clamps, like about 5 more than you have available when you apply the
    glue
    John
    17,515
    Quote Originally Posted by John Downey View Post
    glue
    John
    yeah you read me right john, i thought about biscuts but hesitated thinkun i could do it with a band it worked by hand but that glue seemed to make things alot greasyer. hadnt given the spline a thought culda dun that pretty easily. got 2 more to do and the spline may be my ticket.. did do the wrap affect by accident thanks fer the insight guys
    The Heart of Dixie
    4,268
    Splines or biscuits. Done both but prefer splines. Here is a post I recently made with splines. Just make sure the spline is slighlty smaller than the slot. DAMHIKT!
    Custom built boats and Kits
    17,515
    tanks jeff that is what i is upto.
    Kansas
    417
    Jeff, what did you use to make the slots for the splines, I have seen splines on some bed post once but they were not that thick, they looked like a single pass on the table saw. Just wondering how you did yours.
    Rise above the rest
    688
    Hey Larry,
    Another way to skin the cat on clamping is to use some scrap and nail nice and square 90 degree "L"s onto a piece of ply and use them as clamping guides.
    The Heart of Dixie
    4,268
    Quote Originally Posted by Aaron Beaver View Post
    Jeff, what did you use to make the slots for the splines, ...
    Dado blade on the table saw. Big fan of dado blades, they just work.
    Elgin, IL
    442
    clamps like this work for glue up.
    http://www.collinstool.com/base.php?...ter_clamps.htm
    Randy
  1. Learned a new trick today
    By Dave Hawksford in forum General Woodworking Q&A
    Last Post: 09-25-2014, 06:38 PM
  2. The Eggs Trick
    Last Post: 08-05-2012, 09:47 PM
  3. Another Rafter Trick
    Last Post: 12-10-2011, 12:35 AM
  4. And for my next trick...
    Last Post: 10-29-2008, 08:10 AM
  5. how to teach an old dog a new trick?
    Last Post: 04-04-2007, 05:49 AM
