Results 1 to 8 of 8
Thread: More Questions: Router/Jointer
    Will try to keep these Brief
    * Will the SKIL-1825 possibly use the same 3/Hole pattern as an older Craftsman Router?
    I am Pre-drilled into a new Phelonic Insert and would like to have both 1/4 + 1/2 Collets, and additional power
    * Any suggestions on learning to properly use a new Router table? Need to learn best way to set-up fence, calculate Depth of Cut/Height adjustments, etc.
    Any specific Books recommended
    Are the 6" Bench-top Jointers worth owning, or can you do as well with the Router for this?
    Thamks,
    Bruce N.
    9,077
    Bruce, where are you geographically? If you're close by I could give you a hands-on show and tell that might speed up your learning curve. Not that I'm an expert but, I learn a lot faster if someone shows me how to do something and then I actually do it. I'm in SoCal about 60 miles east of Los Angeles. Just an offer.
    Re-Classed Post: Router/Jointer Questions
    Will try to keep these Brief* Will the SKIL-1825 possibly use the same 3/Hole pattern as an older Craftsman Router?I am Pre-drilled into a new Phelonic Insert and would like to have both 1/4 + 1/2 Collets, and additional power* Any suggestions on learning to properly use a new Router table? Need to learn best way to set-up fence, calculate Depth of Cut/Height adjustments, etc. Any specific Books recommendedAre the 6" Bench-top Jointers worth owning, or can you do as well with the Router for this?
    Note- I mistakenly posted this in the "Classified" area first
    Thanks,Bruce N.
    Bruce, I know nothing about the Skil and Craftsman routers, so I'm no help on that question. As far as learning to use a router table, I've seen this book recommended by others in the past:
    Bill Hylton's Ultimate Guide to the Router Table
    And no discussion on router education is complete without a reference to this book, by Carol Reed (one of our members here), who was "The Router Lady" in a previous life.
    Router Joinery Workshop
    It's not specific to router tables, but it covers a lot of useful ground.
    3,135
    Here is a place that has a lot of info & products he is a router instructor & author as well.
    Pat Warner ROUTER WOODWORKING
    http://www.patwarner.com
    Oct 2007
    Midwest City OK
    20
    Instead if changing routers, just mount the half inch router and use a quarter inch adapter for your smaller bits. Unless of course you are Norm Abrums who changes router, not bits.
    Mike
    Make your "go-arounds" worth waiting for!
    Catalunya
    4,632
    Hi Bruce.
    I'm not expert at all with routers but I have a book called " Cutting edge router tips & tricks" by Jim Stack (Popular woodworking Books) where apart from explaining how to use a router there are several projects of increasing difficulty plus some easy jigs to make.
    I found it very useful and worth having.
    Best regards,
    Toni
    Hey Bruce, I merged the posts in your original thread (in the Classified section) into this one. That way all the replies are in the same place for you.
  1. Router Lift Questions ...yeah i know ....again..:)
    Last Post: 11-28-2012, 01:41 AM
  2. Elementary Router versus Shaper Questions
    Last Post: 11-29-2010, 02:01 AM
  3. General Elementary Router Table Questions
    Last Post: 10-25-2010, 06:57 PM
  4. More Jointer vs. Planer questions
    Last Post: 10-21-2010, 09:37 PM
  5. Incra compatible router bit set questions...
    By Jim O'Dell in forum New Tools
    Last Post: 10-01-2007, 08:53 PM
