Results 1 to 10 of 16
Thread: Are router bits shanks and collets universal?
    Catalunya
    4,632
    The title says it all.
    Knowing the diferences between countries that use metric or imperial system units as per threads, and other things I wonder if router and router bit manufacturers make different shanks and collet diameters depending on the country they are selling their products.
    Does any of you know about this??
    Thanks in advance.
    Best regards,
    Toni
    Dec 2008
    falcon heights, minnesota
    5,610
    as far as i can tell, here in the states, the router bits i've used have either been 1/4" or 1/2". my milwaukee router came with 2 collets, for those size bits. hopefully this shines some light on the problem.
    dan
    benedictione omnes bene
    www.burroviejowoodworking.com
    Yes they "Should Be" 1/4" & 1/2" but some foreign "less than precision" outfits may produce "slightly undersized" shanks. These you must be careful as they may slip out of the Collet.
    Jan 2008
    Beaverton, Oregon
    59
    I have seen some bits with metric size shanks but those vendors offer adapters to 1/2" I have seen Metric saw blade holes as well but I don't know how popular they are. We need someone from Europe to answer.
    17,472
    i agree on some undersized economy bits have had one loosen up..and they also have 8mm bits for the leigh jigs.. but over seas size i dont know toni..
    5,321
    Porter-Cable makes 1/4", 8mm, 3/8", and 1/2" collets for sure (I have them all) and I think they also make a 12mm.
    1/4" & 1/2" are the U.S. 'standards' but the rest of the world uses SI (metric).
    I use the 8mm collet for the (Canadian) Leigh jig bits, and the 3/8" one for using two-flute end mills. The end mills are solid carbide, up-cutting, and are way cheaper than solid carbide spiral router bits.
    17,472
    got a link to the end mills jim?
    Trinity County - 160 miles north of San Francisco. Redwood forest.
    159
    CMT Bits are made in Italy. If you try to find a metric size, you have to look in their very large catalog, not in the small catalog given away free at tool shops.
    I have a few of their metric bits, but these are 1/4" shank. I'll have to check with a digital caliper to see if the shank is 6mm or 1/4"
    I have a bunch of 8mm shank bits from England. And I have no trouble in a half-inch router when I use the 8mm sleeve.
    Gary Curtis
    short answer......yup there are different euro sizes.
    i don`t know what is available in spain so you should find a local supplier and deal with them.
    Catalunya
    4,632
    Thanks Tod ( and the rest) That is what I feared about, I've measured the shanks of my bits and they are 7.97mm that is 0.31" does that make sense to you? I mean do you have 0.31" standard diameter shanks?
    Best regards,
    Toni
  1. HF Router Bits???
    Last Post: 07-29-2013, 12:36 AM
  2. Router collets and/or reducers
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 12-16-2010, 03:04 AM
  3. Cleaning router bits
    By James Brown in forum General Woodworking Q&A
    Last Post: 02-15-2010, 09:22 PM
  4. Router bits
    By Royall Clark in forum New Tools
    Last Post: 02-20-2009, 03:14 PM
  5. Porter Cable 890 Router Collets
    By Kevin Reid in forum New Tools
    Last Post: 12-31-2008, 11:29 AM
