Results 1 to 8 of 8
Thread: Blum Tandem plus Blumotion Drawer Slides
    Jan 2009
    Yellville, Arkansas. Hillbilly country
    2
    Does anyone know how to install these slides? Or, does anyone know of a book, dvd, video of installing these? I have 12 pairs of these and the instructions aren't easy to follow.
    Peter
    Dec 2008
    West Jefferson,Ohio (soon to be Florida)
    29
    slides
    Don't know if it will help Pete but you might try "DIY" website
    Alexandria, Virginia
    1,071
    I went to their Web Site, where they have several files. Because I can't see pdf files here at work you may want to take a look.
    Also check suppliers (Rockler & Woodcraft) to see if they have instructions.
    Woodworker's Supply has some instruction sheets here.
    Santa Rosa, CA
    138
    They are VERY easy to install. What kind of drawer are you using? How thick are the sides? There is a chart (I'm looking on page 21 of the Tandem brochure) for drawer width vs. drawer side thickness. For 1/2 in. sides subtract 5/8" from opening to get drawer width. This is for the 562H full extension runner. YMMV depending on drawer side thickness and the specific runner choosen.
    Inset vs. overlay effects the setback of the runner. Which style of drawer do you have?
    Also are the cabinets face frame or not? Mounting varies a bit with each style.
    Southern Louisiana
    947
    hey peter, they are very easy. assuming you have built the drawers for the slides. they are not like KV ball bearing slides where everything has a 1/2" offset.
    the pdf's on their site are very helpful.
    have you built the drawers? what is the side thickness?
    Go to WWW.WWhardware.com (Woodworkers Hardware) and look up your slides/glides and with each there is an application pdf file, and an Installation pdf file.
    The commercial hardware dealer that I buy mine from had all of the blum alignment fixtures, drill bits as well as screws and screwdriver bits that you need. I do not have the part numbers but your dealer should be able to find them for you. With the blum jigs they are very easy to use and give you a top quality drawer. LOL
    Jan 2009
    2
    Thanks to Everyone
    I finally got through to Blum and they are sending me a brochure that should do the trick. Thanks for everything. Now I have to get some things done. Should be fun.
    Peter
  1. Notching drawer boxes for Blum undermount slides.
    By Karl Brogger in forum General Woodworking Q&A
    Last Post: 02-27-2015, 05:13 PM
  2. Blum Tandem drawer slide help needed
    By Tom Niemi in forum General Woodworking Q&A
    Last Post: 03-13-2009, 12:26 PM
  3. Drawer slides
    By Paul Downes in forum General Woodworking Q&A
    Last Post: 01-29-2009, 03:37 PM
  4. Drawer slides?
    By Brent Grooms in forum General Woodworking Q&A
    Last Post: 02-02-2007, 02:32 AM
  5. Tandem drawer glides
    By Gail O'Rourke in forum General Woodworking Q&A
    Last Post: 12-06-2006, 05:27 PM
