Results 1 to 10 of 17
Thread: Holding log steady while sawing
    Does anyone have suggestions on how to hold a piece of log steady while trimming it down for the lathe. For instance it is pie shaped and I want to saw the corners off, because my harbor freight lathe can't handle the imbalance. I can't hold it steady and saw it at the same time.
    I think I saw this in the AAW magazine, but if you take a fairly large pipe flange and a piece of pipe, say 10" long that is inserted into a heavy base, then you use some good screws to attach the pipe flange to the piece of wood you want to trim, much like a faceplate, then spin the pipe flange onto the 10" piece of pipe, an you have a stand that you can get at all sides of the chunk of wood.
    Then there is this stand.......
    http://www.laymar-crafts.co.uk/tip33.htm
    What kind of saw are you using? Chain saw or bandsaw? For a chain saw, I made a stand patterned after the one Stu linked to. It works great. For the bandsaw, I have this:
Name:	Sled 1 800.jpg
ID:	27754 Click image for larger version.
Name:	Sled 5 800.jpg
    17,475
    hey sir vaughn how are you holding the jig in place on your table?
    Mason Michigan
    455
    Cool Vaughn!
    Did you design that or is that from another plan?
    "Small Change got rained on with his own 38"
    Tom Waits
    5,533
    ooh, I've got to build one of those... that looks sharp!
    -Ned
    Tellico Plains, Tennessee
    4,353
    I built one of these to hold my logs - kinda similar to it anyway... I have about 2 tons of logs to cut up for blanks... it works pretty good... mine isn't as neat and pretty and this one, but it works for me. Really wish I had had a little extra lumber and could have raised the height about a foot, my back gives out after a couple of hours on mine because it's too low.
    I don't know for sure where I saw it, but I saw a sled built for working on a bandsaw.
    Chuck
    Tellico Plains, TN
    It's got a runner of UHMD plastic that rides in the miter slot on the bandsaw (and into the table extension I built). You can see the end of the black plastic runner in the first pic. If you want, I'll post more pics of it later tonight when I get home.
    Pete, it's my "interpretation" of one or more plans I found floating around the 'net.
    4,353
    That's better than the sled I was thinking about.. I'll need to put a riser in my 14" bandsaw before it will work for me though.. great idea.
    Chuck
    Tellico Plains, TN
    Catalunya
    4,632
    Hey Vaughn.
    I like that jig. I assume that the three long bolts on each side are to give three fixing points at the usually irregular shapes so that it doesn't move at all.
    I guess that that same jig could be used for ripping logs as well
    Best regards,
    Toni
  1. Husband and wife team sawing logs
    By Jonathan Shively in forum New Tools
    Last Post: 01-25-2014, 11:41 AM
  2. Hand sawing and lubrication.....mutton fat
    By Rob Keeble in forum Neander Woodworking Q&A
    Last Post: 04-11-2013, 06:18 PM
  3. A visit to Sierra Madre Sawing and Milling
    By glenn bradley in forum Off Topic Discussion
    Last Post: 07-25-2012, 05:01 PM
  4. Sawing wood
    By Paul Downes in forum Off Topic Discussion
    Last Post: 03-28-2010, 12:18 AM
  5. Scroll sawing
    By Al killian in forum New Tools
    Last Post: 02-06-2007, 08:40 PM
