Results 1 to 7 of 7
Thread: What kind of chisel is this and what is it used for??
    Sep 2008
    Tacoma, WA
    84
    A friend of a friend found this in his dad's shop and new that I am a woodworker so he gave it to me. It says "Swiss Made" on the handle and "5<--<-<-" on the blade. The blade width is 2 3/8" (60mm) and has a shallow curve to it.
    What kind of chisel is it and what is it used for?? I can guess for carving slightly concave shapes?
ID:	27757Click image for larger version.
    11,833
    Yep. You answered yer own question. Carving chisel for removing fairly large amounts of wood quickly. Most often for rapid waste removal with a mallet.
    5,322
    It's a carving chisel/gouge, as Frank said. The "5" indicated the amount of sweep (curvature) in the blade. The higher the number, the greater the curvature.
    BTW, a very sharp #3 or #5 is very handy for removing dried glue squeeze-out on a panel glue-up.
    Sacramento, CA
    1,367
    What they said.
    It looks a whole lot like the gouges i've seen used to dish out chair seats. First they use an adze, then they use this tool to refine the shape more. After that, an inshave to sweeten the finish. Then scrapers and abrasives to smooth everything nice.
    Jason Beam
    Sacramento, CA
    looks like a pheil 25-5 sculptures gouge.
    http://www.woodcraft.com/product.asp...&FamilyID=1297
    Honolulu, Hawaii
    1,103
    Also looks like the metal ring that would protect the end of the handle is missing. Those keep the handle from splitting and deforming from being hit with a mallet.
    Maybe you, or one of your metal working friends could turn one out of steel or brass. Most I have seen look like a skinny doughnut. Nice chisel though.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    Quote Originally Posted by Tony Baideme View Post
    Aloha, Tony
    That metal ring you mention is called a "Striking Ring" and yes it needs to be replaced afore it is put back into service. Find a piece of steel pipe with that diameter, cut off a length jusst slightly less than the tenon on the end. (file smooth, etc.) slide it on, any striking in the future will mushroom the end to form a snug fit.
  1. Chisel Rack
    By Steve Southwood in forum Jigs and Fixtures
    Last Post: 07-03-2012, 07:51 PM
  2. Beading Chisel
    By Dennis Kranz in forum Turning Tool Questions and Show & Tell
    Last Post: 05-16-2012, 03:06 AM
  3. now this is a chisel set
    By ken werner in forum Neander Tool Questions and Show & Tell
    Last Post: 12-07-2010, 12:54 PM
  4. Some chisel handles
    By Dominic Greco in forum Neander Tool Questions and Show & Tell
    Last Post: 10-13-2008, 07:26 PM
  5. Another Chisel done!
    Last Post: 09-04-2008, 01:18 AM
