Results 1 to 10 of 20
Thread: chimney question?
    17,471
    chimney question?
    ok ,i now have a chimney block chimney for the wood stove, with clay flues but the flues are stating to break up. amd i lost the outer part of the thimble tonight.... so my question is in a 8x8 flue space can i get a stainless pipe down ther and can i get a new thimble into it? preferablly stainless as well? i am pretty confident i can get the old flues out the bottom with soem patience.. any other ideas?
    North West Indiana
    6,098
    Chuck's solution is probably cheaper than rebuilding that chimney. Otherwise using an air bladder you can lower clay liners back in but the will only be dry fitted.
    Jon
    17,471
    Larry try this http://www.extremechimneys.com/6quot...inin62539.html
    All the stuff you need in one place.
    thanks chuck, but how do you get the tee fished down the chimney????
    Floydada, Tx
    1,941
    The Tee come in two peices, the one part goes onto the liner pipe and the tee part get clamped on when the pipe is lowerd into postion.
    17,471
    ok al ,can you explain how they clamp it to the other part of the tee threw the intake hole ..but it sure looks good from chucks picks. also was told that the creasote wont stick to the stainless???? i dont think that is true,,creasote sticks to everything right..
    Alexandria, Virginia
    1,071
    Seems to me your problems started right about the time you put on that Santa suit I saw in your picture. Didn't try to squeeze down there did you?
    Floydada, Tx
    1,941
    The one part attaches to trhe liner, which is slide down the chimney. The Second part(snout) is held in place by a person on the bottom and the liner slide thru it. The you tigthen up a band clamp and it is secure. Here is a link to the pic that show it.http://www.chimneylinerinc.com/elbows.htm
    Constantine, MI
    7,890
    Quote Originally Posted by Frank Townend View Post
    Now Frank, he's already told you how small the chimney is.
    www.wrworkshop.com
    I saw something about pouring a new flue with a bladder. Similar to this:
    http://www.supaflu.com/products.htm
    Maybe more cost than the stainless solution though.
    FWIW,
    Wes
    Bellingham
    2,449
    Maybe it looked bigger after a few too many barley pops!
