Results 1 to 10 of 10
Thread: Sharpening Card Scrapers
    NW Lower Michigan
    10
    Upon researching the net I found different techniques to sharpen card/cabinet scrapers. I am a little curious on how other woodworkers perform this task?
    Bob
    4,992
    robert, i use stones and a burnisher and freehand `em...tod
    The Heart of Dixie
    4,265
    Sand them on the belt sander or use a file then a hard steel rod for a burnisher.
    Custom built boats and Kits
    Forest Grove, Oregon USA
    290
    Hi Robert,
    I clamp them in my vise, file the edge with a fine metal file, hone the edge using two sharpening stones--a 2k and then an 8k stone the same I would do a smoother--polish the face at the edge, draw the face and do the burr with a burnishing tool. Whole process takes but a couple minutes.
    fwiw, the current Popular Woodworking which just arrived has an article Chris Schwartz wrote about prepairing scrapers.
    Take care, Mike
    Wenzloff & Sons Sawmakers
    Northwest Indiana
    104
    Here's a short video from David Marks. His method sounds much like Mike's.http://www.diynetwork.com/diy/pac_ct...id=62890&c=604
    There is unrest in the forest,There is trouble with the trees
    For the maples want more sunlight,And the oaks ignore their plea's. N.Peart
    290
    Cool. Russ. Thanks for the link.
    Here's another to same video, but bypasses both needing to choose the right category and the commercials.
    It probably will open Windows Media Player separately, or whatever your system has to play WMV files.
    http://wms.scripps.com/library/DIY_N...layer=UP DIY -
    Also note that the first minute is plane blades...
    Take care, Mike
    Heathrow, FL
    91
    There is an article in American Woodworker on this exact subject. Got it today and haven't read it yet.
    In looking at the results David Marks gets on his shows, I'll try his method for sure.
    Brian
    Northville, MI
    507
    Clamp the scraper in the bench, file the top edge with a mill file, flatten the sides with a water stone and lastley use my burnisher to pull the edge. The burnisher usually only takes two or three pulls to make a nice hook. Once you see this process done you won't believe how easy it really is. If I can do it anyone can.
    Jim
    Atlanta, Ga.
    26
    Dittom Mike and several others. About a two minute operation when you get used to it. The card scraper is one of the most used tools that comes out of my bag of tricks along with a low angle block plane.
    And once you fall in love with it.. a cabinet scraper plane (which is sharpened in a different but similar way) is just on the horizon if you do a lot of large surfaces.
    Regards...
    JT.. sarge
    Cumming, GA
    33
    I polish the working edges (about a half inch) to a mirror - then use a bandsaw kerf in a 2" block of wood to stone the edges square. Burnishing is the same. Its not my method, but one in FWW mag article by Brian Boggs. I'll say he's one of the best hand tool guys out there.
  1. card or cabinet scrapers
    By hu lowery in forum Neander Tool Questions and Show & Tell
    Last Post: 08-03-2015, 05:17 AM
  2. Replies: 3
    Last Post: 02-12-2011, 08:05 AM
  3. Sharpening a Card Scraper
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 06-27-2010, 08:36 PM
  4. Sharpening Round and Straight scrapers
    Last Post: 04-09-2009, 03:19 PM
  5. Big Blue Card Scrapers
    Last Post: 03-02-2007, 12:33 PM
