Results 1 to 10 of 10
Thread: Deep Boring
    Qualicum Beach British Columbia
    12
    Deep Boring
    Iím going to ask this question on a couple of forums just to get ideas from a broad spectrum of woodturners.
    Task: I must drill a hole about 10 inches deep + into dry walnut end-grain to start the hollowing process for an urn. Iíve not done this before and Iím a little apprehensive because, even when drilling pepper mills to a depth of 7 or 8 inches, Iíve had the drill bit drift significantly and that has caused severe binding, not as in constipation...well maybe that too.
    What technique do the Ďdeep drillersí of whom Iíll soon be a member, use to bore deep holes into end-grain?
    Thanks, Tom
    Alexandria, Virginia
    1,071
    Hi Tom. I'll let the more experienced turners jump in, and while 10" is mighty deep, I run the lathe at slow speeds, draw out the bit to get rid of waste, and continue to move the tailstock forward between cuts.
    What size bit do you intend to use?
    11,702
    Do the drilling first. Your hole will become the axis. Therefore a little drift won't matter. I prefer brad point bits for this sort of thing. Do withdraw often to remove chips. You can get extensions but, still, 10" is a reach. If you plan to do this often, have a machinist weld an extension to a bit. You will then have a custom tool. I have a couple like that.
    If you are really determined to not have drift, the old fashioned spoon bit works about the best there is. Makers of traditional muzzle loading rifles use these to drill the ramrod hole.
    Have you thought about drilling only partially, turning out that part, drilling more, turning out more, etc.?
    Aug 2008
    Reno, Nv
    3,632
    Drill from both ends Tom. If you have a 1/16" drift per inch and drill 10"...that's a 5/8", pretty bad. But if you drill from both ends, it's negated in the middle. It just dawned on me that you are doing and urn . I'll shut up now.
    Goodland, Kansas
    4,834
    Tom I guess I am the odd man out. I don't drill my Hollow Forms. I just start cutting with my boring bar and hollow it all out. It was how it was shown to me and just never have drilled anything out except peppermills. If I did drill I would stop about a inch from the bottom and when you get there in the hollowing process the bottom should be ok and centered.
    Bernie W.
    Retirement: Thatís when you return from work one day
    and say, ďHi, Honey, Iím home Ė forever.Ē
    Tellico Plains, Tennessee
    4,156
    Removing the bit from th4e work frequently to release the chips. If you don't the bit will bind in the work piece.
    This is a for sure....DAMHIKT... I jammed a spade bit in a peppermill blank by not backing out soon enough.... almost lost both the bit and the blank.. took over an hour to dig enough wood chips out of that blank to finally get the bit out... BE SURE YOU BACK OUT EVERY INCH OR SO TO CLEAR THE HOLE.
    Chuck
    Tellico Plains, TN
    i use an auger held in a pair of mole grips (locking plyers) i've drilled 18" like this with hardly any drift- just remember to stop every inch or so back up and clear the swarf then carry on drilling etc
    Honolulu, Hawaii
    1,103
    Deep Boring
    I generally use a Forstner type/sawtooth bit on the lowest speed on my lathe. That last one I did was a 2" hole in Milo. I went about 4" deep but as good as it was working, I could have gone deeper if the wood was longer. I keep the chips blown out with air and back the bit out about every inch or so. This allows the bit to cool a little too.
    I have not had any wandering using the Forstner bits, as long as they are sharp.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    12
    great replies and info folks. The best part is, no one said "don't go there!" When I screw up my courage sufficiently, I'll give 'er a go!
    Tom
    I too do not drill when doing hollowing work, (Why?) always seemed like a waste of time to me. If you insist on going that way. You could use it as a referance point and a "get started" hole as from that point on the process is simple and to the point. I
  1. Well we seen the deep oil drilling but what about mining.
    Last Post: 07-31-2010, 10:09 PM
  2. hollowing deep
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 06-16-2010, 02:22 AM
  3. Boring a deep hole for hollowing
    Last Post: 01-19-2010, 07:37 PM
  4. Hello from the deep South . . .
    By Kevin Jaynes in forum Welcome and Introductions
    Last Post: 02-13-2009, 09:24 AM
  5. Deep Throat Clamp
    By Dave Richards in forum Jigs and Fixtures
    Last Post: 04-20-2007, 12:59 AM
