Results 1 to 10 of 10
Thread: using podium with sketchup
    Dec 2008
    falcon heights, minnesota
    5,610
    has anyone else used podium with sketchup? i've just started using it, and all i can say is wow! here are some examples...
    benedictione omnes bene
    www.burroviejowoodworking.com
    Sacramento, CA
    1,367
    wow is right ... a few tweaks of the texture and i don't think i would have believed it
    Jason Beam
    Sacramento, CA
    Dec 2008
    5,610
    i know what you mean. it looks like a picture of the real thing....
    Kansas
    417
    What is Podium exactly?
    Rise above the rest
    13,454
    That is pretty cool. can check it out the info below about the plugin Aaron.
    http://www.suplugins.com/
    "The free version will not expire. The free version is exactly the same as the commercial version EXCEPT it only outputs to 230 X 120 and 500 X 500 image resolution sizes."
    SE Minnesota
    2,526
    Aaron, Podium is a rendering application. There's also Kerkythea which is also free with a free exporter and light components. It has no output size limitations and will support multiple scenes and animation.
    Dec 2008
    5,610
    since i am using the free version of sketchup 7, how can i get my files into kerkythea to be used?
    SE Minnesota
    2,526
    It doesn't matter that you are using the free version of SU. You need the SU2KT plugin. You can get it here.
    Dec 2008
    5,610
    thanks! first time i used podium, i thought it was like looking at a picture.
    SE Minnesota
    2,526
    The photographic look can be nice but in order to make it work right you need to use some very good materials, especially wood grain materials.
    I like doing a combination of rendering and line drawings. This is dead simple stuff and quite quick to do.
    By the way, it isn't real noticeable but I put a point light source under the near raised desktop to get a little light inside.
  1. Building the Ambo (lecturn, podium) - Final Picture
    By Don Baer in forum Flatwork Project Showcase
    Last Post: 07-29-2010, 03:11 PM
  2. Speaker's podium
    By Jim Hager in forum Flatwork Project Showcase
    Last Post: 04-19-2010, 11:38 PM
  3. DXF to SketchUp
    Last Post: 06-25-2007, 11:07 PM
  4. An Example from SKETCHUP 6
    Last Post: 01-13-2007, 12:32 AM
  5. A Thing I Just Learned About SU and Podium
    Last Post: 12-12-2006, 04:19 PM
