Results 1 to 10 of 10
Thread: quick guide- spalted beech vase
    hello all, heres a breif step by step guide to a vase/hollow form i did last year, this paticular piece took me about 2 hours but i would suggest that everyone always work safely and at their own pace,this is only a brief guide as to how I choose to work,it is not intended to be a strict "you must do it this way" etc
    heres the blank between centres, the blank measured about 20" long by 9/10" square ish. i cut these blanks from a much larger log, next time i need to cut some more i will try to remember my camera and show how i cut the log up and why i choose to do it that way.
    the white ends are because i cut the wood to use- then i didnt get chance to turn for a few days so to save splitting i painted the end grain with some old oil based paint until i had chance to turn them.
    here it is knocked into the round
    a view of the end grain, i decided to use this tailstock end as the top because the spalting looked much better on this end.
    i've taken it from between centres now and attached a 6" faceplate using square headed sheet metal screws which give excellent grip into end grain- these screws are a mix of 3" and 2 1/4" in length
    right here is the shape roughed out, the blank is a bit too long but i will find a use for the extra bit later.
    here is the shape refined a bit more, i'm trying to get a nice flowing curve.
    i leave an area near the base (far left of the photo)extra thick to support the hollowing process.
    top view of the neck and start of the hollowing, i make a hole down to the bottom the same daimeter as the neck first and then starting from the top down hollow it out to my final wall thickness.
    this ones slightly blurred, but it shows where i hollowed down to marked in pencil
    here is the outside shape finished, i go back inside now and hollow the final bit from the base.
    here it is sanded to 320 and oiled with lemon oil
    close up of the neck
    a bowl from the extra wood/ waste block
    here it is hollowed out and sanded, i've got it on my vacum faceplate so i can clean up the base
    heres another slightly blurred!! photo of the days work, a burr elm hollow form, a bangle and both spalted beech bits.
    and heres the mess i've made!! you can also see my hollowing tools in the background-but i will post a seperate thread with some better pictures of these soon.
    Mason Michigan
    455
    Thanks a ton, George!
    Is that a Vega Lathe?
    "Small Change got rained on with his own 38"
    Tom Waits
    Hi Pete- no its a VB36- superb lathe's
    Great documentation George. Thanks for posting it.
    Jul 2007
    DSM, IA
    5,719
    Thanks George!
    My Website
    Oct 2007
    Harvey, Michigan
    687
    Very nice little tutorial George! Will have to give this a try!
    Steve
    15,809
    Well done indeed, and that is no mess, you can still see the floor.............. in places
    Goodland, Kansas
    4,834
    Great tutorial George. Thanks.
    Bernie W.
    Oct 2008
    Upstate New York
    23
    George
    That is some nice stuff - I never read about putting oil based paint on the ends - how long did you let it sit and did it warp after you made it.
    Jack
    sorry folks i have had some sort of problem with my photobucket account- all of my pics have been either moved or deleted and i have no back ups.
    could admin please remove the affected threads
    many thanks
    george
  1. Spalted Beech
    Last Post: 01-17-2012, 11:37 PM
  2. beech vase
    Last Post: 03-26-2011, 12:25 PM
  3. Spalted beech potpourri pot
    Last Post: 12-07-2010, 12:01 AM
  4. spalted beech
    Last Post: 05-31-2010, 04:33 PM
  5. Spalted beech
    By Pete MoncrieffJury in forum Lathe Project Showcase
    Last Post: 02-25-2009, 07:39 PM
