Results 1 to 4 of 4
Thread: Tutorial: Jig for card scraper prep
    This is one of those ideas that pop into my fevered brain from time to time and I thought I would share with those who want to roll their own . I have one out for beta testing but I can tell you it works great to hold a card scraper at 90* to a file or stone or sandpaper.
    You will need 18" of 1" angle. I've used both 1/16" aluminum and 14 ga. galv. steel; both work but the steel will probably hold up better. Four shower door rollers. These are available in 5/8, 3/4/ and 7/8" diameter and are secured with machine screws (8-32 x 3/8 or 1/2 pan head). Four pop rivets or four sheet metal screws or four small nuts and bolts. Two 1" long 8-32 or 10-24 (or 32) panhead machine screws with nuts and washers. Two pieces of compression spring. I bought a 3/8 x 1.5" spring and cut it in half. All these parts are available at BORGS and real hardware stores.
    Dimensions are not precise. Cut four 3/4-1" pieces of angle for the legs. Square cuts look nice, but aren't critical. Cut two 7" pieces of angle. At this stage I use a belt sander to round all the corners and deburr the edges.
    Drill holes in the legs for mounting the rollers and for securing them to the main angles as pictured. Holding the main angles together, drill a hole to match your 1" machine screws through each end about 1/4" from the end and about 1/2" down from the top edge.
    Assemble as pictured. The second photo shows the springs mounted to the machine screws with washers and nuts. It doesn't take much spring to hold the angles together, In use, your hand squeezes the angle and pushes down on the scraper. I found that mounting the legs on top of the main angle (1st photo) allows the legs to square themselves and only one fastener is needed.
    If you want to straddle a stone, I think wider and/or taller legs.
    Bob Ross
    WALNUT ACRE WOODWORKING
    Ideas, Products & Accessories for Serious Safety-Minded Woodworkers
    www.walnutacrewoodworking.com
    Please Pray for Our Troops
    Semper Fi!!
    Bellingham
    2,449
    Clever idea Bob! I have been filing and stoning by hand, trying to build up the ability, but every now and again I need an aid to get me square. It is the same principle that I am using in sharpening my chisels and plane blades. I try as much as possible to do it by hand without aids, but I need to "right the ship" every once and a while. I then use a jig to get me back to square one.
    Thanks for posting your idea.
    17,474
    glad to see your been thinking again bob that looks pretty handy. and not much moola either.. maybe this handtool forum can get back up to speed again, i see we are gettin more folks involved in it thanks for your input and pauls as well earlier today.
    Nova Scotia's beautiful south shore
    443
    Hi
    I heard something stirring down here in the basement, thought I'd check it out.
    That looks like a pretty handy rig. Creative problem solving is the neander way!
    Cheers
    Ian
    All the best,
    Ian G
    **Now holding auditions for a catchy new signature**
  1. Card Scraper Holder
    Last Post: 12-27-2012, 02:56 PM
  2. Card scraper question
    Last Post: 06-21-2012, 06:33 PM
  3. Sharpening a Card Scraper
    By Brent Dowell in forum General Woodworking Q&A
    Last Post: 06-27-2010, 08:36 PM
  4. Sharpen a Card Scraper
    Last Post: 11-14-2009, 03:24 AM
  5. What a card...scraper
    By Alex Reid in forum Neander Tool Questions and Show & Tell
    Last Post: 03-05-2007, 02:36 PM
