Results 1 to 10 of 12
Thread: Compressor for wood turning ??
    Palm Springs, Ca
    1,166
    In my area on a for sale by owner site is a Brand New still on the pallet - 135 PSI max Air Compressor, never used, 7 HP motor , Made by Husky, 60 gal vertical tank- ------- thats all the ad says..........im not expert on compressors and would like a larger one than the little pancake one im usiing, not sure about stages and all the ratings stuff so i thought i would ask the turners here if this is a good one for the garage at home to run nail guns, sanders and so forth on ? asking price is $250.00........
    comments ??? thanks Dan
    http://palmsprings.craigslist.org/tls/1002230578.html <--------ad with picture...........thanks for any help
    Inside the Beltway
    2,666
    That one's better than my husky, and I paid more! Make him fire it up before you buy, but think about it seriously!
    Oh, and bring hearing protection!
    Word of caution: mine won't run a sander (something about the CFM). Check what a likely sander will need before you buy...
    Bill
    3,134
    It's a Campbell Hausfeld air compressor all dressed up in red paint run away as fast as you can. Campbell Hausfeld is known for having problems. I have seen at least 2 or more models of these upright units side by side 1 blue & 1 red other then that you can't tell the difference.
    Nov 2008
    Tampa & NC
    432
    Compessor for woodworking
    I have to dissagree about Campbell hausfield compressors.I have been using them for yrs and have one now and never had a problem with them.We used them in our bodyshop ans auto repair shops where all you use is air and I think they have proven there selfs pretty good.NOW if this is an after market copy,then I would be carefull,but that should run about anything you want.If possable see if you can fire it up,then take along a sander and hook it up and see how it runs.In fact,thats what I would do,cause once you drive off with it,its yours and if it doesn't work,you may be stuck with it.
    Oct 2008
    1,357
    CH worked well for me. Had a 20 gal. 2 hp for about 20 years. Had to up-grade when I started spaying lacquer, it just couldn't keep up. I ended up getting a 6hp DeVilbis (spl?) with an 80 gal tank. It was a son of a gun to ship over here
    As far as sanders... Look into the Dynabrade. They are used in a lot of autobody shops and sip the air. A bit on the expensive side That's why I don't have one. Yet
    Aloha,
    30,002
    Dan, it sounds like a decent deal for the price. (I'm assuming it's this one.) For woodturning it should do what you need it to do, and should beat the pants off the typical buzz-bomb compressors many of us have (or had) in our shops. It'll probably run something like the Grex pneumatic ROS without too much trouble.
    For clarification, I want to add a few comments...
    The "7 hp" rating is marketing smoke and mirrors. The only time that motor generates 7 hp is the brief instant before it bursts into flames after locking the motor shaft. If it runs on 220v power, my guess it that it's more like 3 hp.
    Horsepower ratings are meaningless with compressors anyway. What matters is the number of cubic feet per minute the pump can squeeze.
    Bart is right about Husky being a rebadged Campbell Hausfeld. CH used to make really good compressors, but in recent years their quality has declined as they've taken more of their operations overseas, and as they've cut corners to reduce costs. The same situation has happend somewhat with Ingersol-Rand, particularly their "consumer" grade compressors.
    Palm Springs, Ca
    1,166
    Vaughn - Bart and gang - compressor update
    I wrote the guy and asked him what manufacturer the motor is.....he said it was Emerson............any comments ??? thanks
    3,134
    Emerson makes good motors its the pluming & compressor head you need to worry about.
    Honolulu, Hawaii
    1,103
    Dan,
    Does look like it would do what you want. If it's got a cast iron pump, it should be OK. If it's aluminum, then I'd say it might be "Iffy".
    The price seems good enough.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    30,002
    Yep, and since it's new and on a pallet, I suspect the plumbing and head are ready to go.
    Dan, I'd say go for it if you need a compressor. (And who doesn't?)
  1. Turning Dry Wood?
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 05-05-2014, 11:20 PM
  2. Wood turning
    By Joe Suckley in forum Old Ads
    Last Post: 02-22-2011, 10:44 PM
  3. A Bit of Turning Wood
    Last Post: 01-13-2010, 04:07 AM
  4. Compressor for Garage and turning ?
    Last Post: 06-07-2009, 02:37 AM
  5. HI new to wood turning
    By Zack Massey in forum Lathe Project Showcase
    Last Post: 04-25-2008, 04:43 AM
