Results 1 to 10 of 11
Thread: Another round of Cutting Boards
    5,533
    Well the shop was at almost freezing temperatures, er, thawing temperatures today, so this evening I fired up the kero heater and electric radiator when I got home from work.
    I headed out after supper and planed down some glued up phase I cutting boards. I then cut them into 1 1/4" (or so) wide strips. Then I planed some more strips to the same thickness which I'll glue up into more Phase I boards after I finish some 'home' work (dishes), and some work -work.
    I've got one large board to make for the house, plus two for friends who asked for boards before the hollydaze. pics to follow in the morning.
    -Ned
    Sep 2007
    Central (upstate) NY
    1,457
    These must not be end-grain boards if you're sending them through the planer. Doesn't the glue scrag the planer blades?
    What is the advantage of end-grain cutting board?
    5,533
    Quote Originally Posted by Mark Kosmowski View Post
    Mark,
    sure are end grain boards, sacrificial long grain boards on either end for the final planing solve the tear out problem according to Vaughn. I haven't used them yet. and yes the glue is a little rough on the blades, but they were/are old blades on there anyway. I also knock off as much of the glue as I can with a paint scraper.
    As for the advantage, the end grain separates and heals up easier when the knife cuts into it, as compared to long grain boards.
    -Ned
    17,475
    hey ned yur supposed to be making a box!!!! not boards silly guy
    5,533
    and I also made progress on that front as well...
    -Ned
    Nov 2008
    outside of Toronto, Ont
    183
    Another advantage of end grain cuttingboards is that the knife blades do dull as quickly because the blade simply pushes the wood fibres apart instead of cutting them.
    Alexandria, Virginia
    1,071
    Quote Originally Posted by Paul Brubacher View Post
    Ned is so busy making those cutting boards he forgot to check his post before hitting the Submit button.
    "do not dull as quickly..."
    5,533
    Quote Originally Posted by Frank Townend View Post
    pssst Frank... Paul, not Ned...
    -Ned
    1,071
    Quote Originally Posted by Ned Bulken View Post
    Nor did I it seems. Sorry about that, first mistake I have ever made....
    17,475
    YEAH RIGHT!
  1. Cutting boards...
    Last Post: 09-28-2012, 04:06 PM
  2. Some Cutting Boards
    By Gary McFarlane in forum Flatwork Project Showcase
    Last Post: 10-17-2009, 09:59 AM
  3. cutting boards
    Last Post: 08-06-2009, 06:29 PM
  4. The Last of the Cutting Boards
    By Sean Wright in forum Flatwork Project Showcase
    Last Post: 12-21-2007, 05:40 AM
  5. Cutting boards
    By Jim King in forum General Woodworking Q&A
    Last Post: 02-09-2007, 08:20 PM
