Results 1 to 10 of 13
Thread: An alternative Festool systainer tool organizer
    Toronto, Ontario, CANADA
    2,332
    Recently there has been a thread (http://festoolownersgroup.com/index.php?topic=6030.0) on the Festool Owner's Group Forum about the tool organizer systainer 4 insert.
    A lot of ideas have been presented and one of them by Pererm encouraged me to attempt to build a "better" tool organizer.
    Mine combines the design of the one that Peterm built with the design of the original from Festool.
    The insert is made out of leftover pieces of Baltic Birch -6mm and 10mm.
    First here is a pictures showing the origninal tool organizer in use (as it was two days ago):
Name:	Tool Organizer 1 -Festool's filled with Frank's stuff -small.JPG
    And here are the contents spread out on my workbench:
Name:	Tool Organizer 2 -Festool's -Contents -small.JPG
    This is the insert sold by Festool:
Name:	Tool Organizer 0 -Festool's insert -small.JPG
    Except for the small wooden box at the bottom right, it's all one piece.
    My objective was to create a set of inserts that could hold more tools and stuff than Festool's and to have those tools and stuff better organized and more accessible.
    I decided that it would be better to have trays that could be removed separately, rather than as a set (as Peterm did). Also, I like the holes in Festool's insert, so I decided to have some -not as many, but some.
    Here is the bottom tray:
Name:	Tool Organizer 3 -Frank's -Bottom Tray -small.JPG
    And, here is the middle tray:
Name:	Tool Organizer 4 -Frank's -Middle Tray -small.JPG
    The middle tray handle fits over the bottom (which protrudes through a slot in the bottom of the middle tray). At the same time, it is short enough that it does not interfere with the top tray. The divider is removable.
    Here is the top tray:
Name:	Tool Organizer 5 -Frank's -Top Tray -small.JPG
    And, here are all three trays (plus some stuff that I stuffed down the small gaps at the sides) sitting on my workbench.
Name:	Tool Organizer 6 -Frank's -Contents -small.JPG
    As you can see, I managed to get everything that was originally in the systainer plus a lot more back into the systainer. And, everything is easy to get at.My objective was to create a set of inserts that could hold more tools and stuff than Festool's and to have those tools and stuff better organized and more accessible.
    Cheers, Frank
    Orem, Utah
    935
    I'd say that you accomplished your goal "in spades". Well done!
    Alexandria, Virginia
    1,071
    Nicely done Frank! May I ask where the brass slide-in dividers for the middle tray came from?
    2,332
    Quote Originally Posted by Frank Townend View Post
    Thanks Frank.
    The divider brackets that I used in the middle tray come from Lee Valley. Here is a link: http://www.leevalley.com/hardware/pa...=3,43722,43743
    Cheers, Frank
    2,332
    Quote Originally Posted by Kerry Burton View Post
    Thanks Kerry. Yes, things worked out even better than I thought they would when I started upon the "experiment".
    Cheers, Frank
    1,071
    Thank you Frank!
    5,533
    Frank,
    you've done it again! My shop Might, someday, faintly, in a roundabout way, resemble just a portion of your organizational skills. I fear it is a lost cause however, as I know how 'organized' I tend to be. I AM going to tackle the clutter this weekend however, and I'm working on a plan for my storage cabinet's internal shelving unit (metal cabinet, getting plywood shelving)
    -Ned
    30,015
    Very nice, Frank.
    3,134
    Frank it looks like your time, brain power & skill combined to pull off another great project. Divide & conquer.
    2,332
    Qwas on the TalkFestool forum suggested that one might want to make some alternate trays and fill them with task specific items. He mentioned Electrical and Plumbing.
    I followed up on his idea this morning and made a two additional middle trays. Right now, I have filled one with Plumbing stuff and the other with Dowelmax stuff. Here is picture of all three middle trays:
Name:	Tool Organizer 7 -Frank's -Middle Trays for Dowelmax, Plumbing, and Woodwork -small.JPG
    I will also make at least two additional bottom trays (once I purchase some more little plastic boxes). But, I will keep the top tray the same for all (unless, of course, I devote a second systainer 4 to holding my stuff).
    Cheers, Frank
  1. Anchorseal Alternative
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 05-18-2013, 01:32 AM
  2. Battery Organizer
    By Daris Robertson in forum Flatwork Project Showcase
    Last Post: 03-15-2013, 09:01 PM
  3. A great tool for handing hard-to-remove vinyl tiles -Festool Scraper
    By Frank Pellow in forum Carpentry and Construction
    Last Post: 02-24-2012, 02:22 PM
  4. Organizer box
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 02-13-2011, 03:36 AM
  5. Carry-on systainer for office/computer/camera use
    Last Post: 03-06-2010, 01:38 PM
