Results 1 to 10 of 18
Thread: More boring again
    Aug 2008
    Reno, Nv
    3,632
    More boring again
    I know we just hit this, but using my Jet mini for 10-12" peppermills with a forstner bit is leaving me about an inch short in the middle. Would an auger bit work better? I bore half from the top and half from the bottom to equalize any deflection. I ordered an extension for my forstner bits, but would the auger do the same thing for boring out the core using the same method? Bit sizes are 1" and 1.25".
    Alexandria, Virginia
    1,071
    Because you are "meeting in the middle" I don't see any issues using an auger bit. There would be too much tear out if you were going all the way through in one pass. Always back out the bit once in a while to reduce heat and chip build up.
    11,831
    When I started making duck and game calls, I found that Forstner (style) bits were not the best thing for end grain drilling/boring on hard-hardwoods. I much prefer brad points. With those, you can easily add an extension for what you are trying to do. Augers will work but, if hand held they are very difficult to keep straight. BTW, spade bits are not bad if kept sharp and they tend to run cooler.
    Aug 2008
    Reno, Nv
    3,632
    I tried a spade bit that was sharp and got a lot of abuse from it. I'm using a jacobs chuck in the tailstock, as it should be used, at about 500 rpm. I'm wondering if the extension on the forstner will wander more or if the auger will be ok doing the half and half . Are brad points made in 1" and 1 5/8" sizes?
    Nov 2008
    Tampa & NC
    432
    more boreing again
    I use the extention with my forestner bits and they work pretty good.They recommend that for a 1" forestner bit to keep the speed around 200 rpm,if your lathe doesn't go that slow,then you just have to take you time and go slow,keeping the chips clear.I'v never had a spade bit that would go straight.
    Drums, PA
    292
    I use forstner bits and extensions when needed. I start by just letting the tip touch the wood and when it finds it's center I start drilling. Seems to work for me.
    Here is a video of me drilling into the endgrain of hard bubinga. It is a 2" bit and the lathe is running at around 500 rpms.
    Drilling endgrain
    11,831
    Quote Originally Posted by Jim Burr View Post
    Yes, large brad points are made but they are costly.
    Forstners, if used on end grain should run r-e-a-l r-e-a-l slowly. Forstners are not designed for end grain work.
    Now, I'll qualify a bit. There are a number of Forstner 'style' hole saws on the market with different teeth and cutting abilities. My experience is with original Forstners and original Forstner style bits. I do not like for end grain, especially on hard-hardwoods.
    Brad points rule.
    Goodland, Kansas
    4,834
    Jim I got a set of these bits from MCLS but see they don't have them on there website anymore. That is to bad as with a extension these things are hefty and don't drift like the regular forstner bits do. They have carbide tips and a screw tip in the middle. Glad I got mine when I did. Haven't been able to find them anywhere else on the net.
    Bernie W.
    11,831
    Try some out on end grain boring of a hard-hardwood. Give us a review.
    Goodland, Kansas
    4,834
    Already have Frank and they are slick. They cut real well and like I said don't wonder. Did this on some end grain black locust. That is about as hard as you can get without turning concrete.
    Bernie W.
  1. When boring goes bad
    Last Post: 02-23-2012, 04:24 AM
  2. Those Boring Tools
    By Paul Douglass in forum Turning Tool Questions and Show & Tell
    Last Post: 09-26-2010, 07:40 PM
  3. Another bit of end-grain boring.
    Last Post: 02-19-2009, 05:26 PM
  4. Deep Boring
    By Tom Storey in forum General Woodturning Q&A
    Last Post: 01-19-2009, 04:14 PM
  5. end boring problem
    Last Post: 10-29-2008, 05:16 PM
