Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: Oval table top
    Floydada, Tx
    1,941
    Oval table top
    Well the wife wants a oval table that is 72" L x 36" w and exspands to around 96" or so. Now this has me stumped as to how the heck the would work. If you strech out a oval it will change shape and the extensions will not fit proper. Looking for ideas on how to do this. My idea was to make it like a oval when closed, but when stretched it will look more lick a pickle has the wife said. And when asked what type of wood she wanted, she said what ever as long as it has a pretty look to it.
    Dec 2008
    falcon heights, minnesota
    5,610
    my advice is to make a paper or cardboard mock up of the top and show it to her. then hide...
    benedictione omnes bene
    www.burroviejowoodworking.com
    Floydada, Tx
    1,941
    That sounds like a idea. Want something real funny? She asked if I good make it with one one small column under the middle to hold it up.
    Dec 2008
    5,610
    you had best get to the doc soon. if i had to bite my tongue that hard, i would need stitches...
    SE Minnesota
    2,526
    Al, I wonder if you are thinking of an ellipse. An oval has straight sides and a circular radius at each end. Often an ellipse is called an oval but they really are different.
    Here's an oval table:
    And here's an elliptical table:
    If she wants an elliptical extension table, make the sides of the extension(s) straight and put them in the middle.
    dave`s 100% correct (of course)........
    much easier to do your first single curvature project by incorporating straight sides. a pedestal base really isn`t that dificult even with extentions. holler if you decide to go any further with the idea.
    Floydada, Tx
    1,941
    Thanks, She says elliptical table w/ two pedestals under it. Mow for the fun part trying to lay one out that looks good. I am going to the lumber yard tommrow and picking up a few sheets of hardboard for templates.
    Quote Originally Posted by Dave Richards View Post
    ...An oval has straight sides and a circular radius at each end. Often an ellipse is called an oval but they really are different...
    I was thinking the same thing, but looking it up, it seems to not be quite correct.
    http://en.wikipedia.org/wiki/Oval
    http://en.wikipedia.org/wiki/Ellipse
    I always thought an oval was a pair of 180 radii connected by two equal straight sides, just like the oval table you showed a picture of.
    SE Minnesota
    2,526
    Hmm...then what do you call that shape of two semi circles joined by two parallel line segments?
    Lake City, Florida
    498
    I would argue Dave is correct in calling it an oval. If you look at the definition
    In technical drawing an oval (from Latin ovum, 'egg') is a figure constructed from two pairs of arcs, with two different radii (see image on the right). The arcs are joined at a point, in which lines tangential to both joining arcs lie on the same line, thus making the joint smooth. Any point of an oval belongs to an arc with a constant radius (shorter or longer), whereas in an ellipse the radius is continously changing.
    The figure Dave suggests fits the definition, Two pairs of arcs, with two different radii. The second pair of arcs has a radius approaching infinity, resembling a straight line.
    Man, I should have been a Lawyer!
    Tony
    Tony, BCE '75
  1. Oval turning?
    By Tom Baugues in forum General Woodturning Q&A
    Last Post: 10-05-2009, 12:06 AM
  2. Shaker Oval Boxes
    By Don Orr in forum Flatwork Project Showcase
    Last Post: 03-24-2009, 01:54 PM
  3. First oval turning
    By Ad de Crom in forum Lathe Project Showcase
    Last Post: 05-20-2008, 06:41 AM
  4. Oval Bat Box
    By Jerry Gilman in forum Lathe Project Showcase
    Last Post: 09-22-2007, 03:06 PM
  5. DC - Rectangular/Oval Ducts?
    By Rob Bodenschatz in forum Carpentry and Construction
    Last Post: 03-10-2007, 04:40 AM
