Results 1 to 4 of 4
Thread: hunka wood question
    11,899
    hunka wood question
    I was given this hunk of mulberry. It is well aged indoors, maybe ten years. I'm not sure if I should try turning into a large bowl (after pre-rounding with the chain saw) or splitting in two and making two vases. Remember, my lathe is a 1/2 hp with slowest speed of600 rpm. The hunk is about 19"X14"X9" thick.
    p.s. that's not a split on top, it's a saw mark.
    Frank,
    I've turned bowls up to 12" on my Rikon with it's 1/2 hp motor. The lowest speed is 420 so I have about 50% more torque then you do and it's slow going. You have to take very light passes due to the power required to remove material at the outside of the bowls.
    30,225
    After carefully studying the picture, I've come to the conclusion that the best solution would be for you to box that nasty old piece of dried-out wood up and send it to me.
    Problem solved.
    My lathe goes a little slower than yours, but I'd think with care and light cuts you could make a bowl with that hunk. Since it's dry, it's likely to be a rough ride, especially at first, but still doable. On the other hand you could get two pieces for the price of one if you go with the vase idea. I guess it all boils down to which option is in your comfort zone.
    After studying the picture I'd make several blanks from that chanka wood. Slice it up on the ole band saw you could get two bowl blanks and two candle stick otta it ..
  1. Wood question.
    By Rob Damon in forum General Woodworking Q&A
    Last Post: 07-20-2009, 02:04 PM
  2. Question(s) regarding Wood
    By Bruce Niceley in forum General Woodworking Q&A
    Last Post: 03-15-2009, 05:31 PM
  3. A wood question
    By Joan Keeler in forum Turning Tool Questions and Show & Tell
    Last Post: 01-03-2008, 11:34 PM
  4. Hunka Hunka Chunka Wood.......How would you slice it...?
    By Stuart Ablett in forum General Woodturning Q&A
    Last Post: 02-17-2007, 08:41 AM
  5. Hunka Hunka Turning Love...........
    Last Post: 12-09-2006, 05:57 AM
