Results 1 to 10 of 14
Thread: Pattern cutting on the shaper?
    The Heart of Dixie
    4,268
    I may have a need to make some repeat parts out of plywood. Frames for a kayak. I was thinking of pattern bits for the router. Then I got to thinking that this would be a good shaper project. Just need to pick up some rub collars.
    But for some reason I am not really comfortable with this but I don't have any reason either. A lot of times when that inner voice speaks it's wise to listen. So what I am missing here?
    Custom built boats and Kits
    you can overpower a router.......not a shaper!
    for rough stuff like you`re talking about i`d use a bandsaw pattern follower.....if you need really clean edges then do a final cut with the shaper.
    rub collars (ball bearing type) ian`t cheap!
    17,472
    ok tod whats a bandsaw pattern follower? the operator or a jig for the bandsaw?
    Floydada, Tx
    1,941
    Larry, Rockler sells them. They act like a bering and follof to template.
    17,472
    will have to ck them out nevr herd of them but thats not the first thing i didnt know huh
    Although it requires more concentration, cutting outside the line will also work on the bandsaw, as for the tracer bearing for the shaper, shaper is "Stronger" and will require less force than the Router. IMHO
    i make my own pattern followers from scrap off the floor.....just cut a notch in the end of a board barely big enough for the blade and align the outside edges of the notch with the outside of the blades kerf.......
    i know i`ve built a few and posted pics but maybe it was during the smc days?
    if ya`ll need pics i`ll build another one.
    17,472
    ill do a search to see what i can find tod,, i think i got it but will lok it up..
    The Heart of Dixie
    4,268
    Not seen one either Larry but going to look for one. I also need to cut out the insides so I can only do half the cut on the bandsaw. That is why I was thinking router or shaper.
    Todd, I think you hit it. The shaper can snatch it from my hand and pull my hand in. I think that was what the little voice was saying.
    Blatant thread-jack - And on sale too: http://www.rockler.com/product.cfm?p...%20guide%20pin
  1. 9 Carving and Pattern Books
    By Mike Turner in forum Classified Ads
    Last Post: 06-23-2012, 09:01 PM
  2. Looking for Nativity pattern
    By Mark Wingate in forum Designs, Plans and Sketches
    Last Post: 09-23-2009, 02:09 PM
  3. Pattern routing problems
    By Jay Lock in forum General Woodworking Q&A
    Last Post: 04-24-2007, 12:55 AM
  4. Using a router for pattern cutting
    Last Post: 03-25-2007, 08:49 AM
  5. back cutting small radiused mouldings on the shaper
    By tod evans in forum Jigs and Fixtures
    Last Post: 11-10-2006, 05:44 PM
