Results 1 to 10 of 18
Thread: Double Sided Tape
    Dec 2008
    Portland, Oregon
    1,898
    Double Sided Tape
    I bought a couple rolls of double sided tape from HF to use on router templates. It sticks great and works fine, but it is a mess to cut, it sticks to the scissors and leaves a residue on them. I spend more time cleaning the scissors than routing, any one else have this problem?
    Jesus was a Woodworker
    Inside the Beltway
    2,666
    I gave up on scissors for that, now I use a sharp craft knife or a retractable utility knife. Works great If you use a backer board when cutting...
    Bill
    That type of tape is pretty gummy for woodworking. Turner's tape is more money but less hassle.
    Alexandria, Virginia
    1,071
    It sure does gum up the scissors Dan. I wipe them with Mineral Spirits after cutting. I think I might follow Bill's route, but horizontal space is always hard to find.
    Oct 2008
    1,357
    I've used wax paper in the past. Pull what you want off the roll onto the wax paper. After you've cut it off you can handle it a little easier with a second "paper backing" Made my tape a little more manageable. I don't remember what brand it was but it was a pain to work with.
    Aloha,
    Rhode Island
    800
    I usually use carpet tape & a utility knife with a backer board.
    Oct 2007
    Midwest City OK
    20
    I use a bar of soap or parafin wax in a pinch. Just rub the scissors every couple of cuts and there will be a clean cutter when you are finished.
    Mike
    OK
    Make your "go-arounds" worth waiting for!
    Jan 2009
    Mableton (near Atlanta), GA
    25
    I learned early on that turner's tape outperforms carpet tape but the thing that stymied me was how to remove the backing after I had applied the tape to one surface. Trying to pick at an end proved fruitless. A little experimentation showed that if you score the backing for about 1/2 inch from the edge about 1/2 inch in from one end then you can peel it back and then pull the whole backing loose.
    1,071
    Good tip Larry.
    Gee your first post is a tip, that may be a record.
    Welcome to the Family, we are all exceptionally nice and civil, each make over a million dollars a year, and each have 300 workshops. One of these is true, can you guess which one?
    One thing I ask, can you put your location in your profile, just click User CP.
    Quote Originally Posted by Frank Townend View Post
    Good tip Larry.
    Thread-jack: Yeah, maybe we oughta ask the admins to check that out. Most first posts are intros / questions. I wonder how many first posts have been tips? Larry may be the harbinger of a brave new world. . . . OK, too much coffee, back to the shop.
  1. Better than double sided tape
    By Jay Caughron in forum Jigs and Fixtures
    Last Post: 04-07-2016, 05:30 PM
  2. Double Sided Coin Project - XYZ Zeroing
    By Brent Dowell in forum Programming, Troubleshooting, and Q&A
    Last Post: 01-18-2016, 02:29 AM
  3. Double Sided Tape
    Last Post: 02-11-2014, 03:52 AM
  4. Double sided tape?
    Last Post: 09-06-2011, 08:47 PM
  5. double sticky tape?
    By Frank Fusco in forum General Woodturning Q&A
    Last Post: 10-05-2008, 10:40 PM
