Results 1 to 3 of 3
Thread: M and T joint ?
    oswego county , upstate n.y.
    280
    M and T joint ?
    hi all
    is there a diffrence in strength between a through tennon and a mitered tenon for table legs and aprons ?
    another question , whats the deal with a haunched tennon and why do i need it , over a straight tennon ?
    thanks in advance !
    what are you building today ??
    GRIZZLY
    Dec 2008
    falcon heights, minnesota
    5,610
    one of the items that i've made with through tenons was a cradle for the newest nephew. the visible part of the tenon was mortised for a key (a pointy bit of wood, for some that i've needled before), to lock everything in place. a haunched tenon would be used when you are attaching an apron to near the top of a leg, and basically it's top is a bit lower (say if you go 3/8" on each shoulder normally, you would use 3/8" on the bottom, and say 1/2" on the top), the result is that there is more wood between the mortise and the top of the leg.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Inside the Beltway
    2,666
  1. Joint Cam
    By Darren Wright in forum Programming, Troubleshooting, and Q&A
    Last Post: 03-11-2015, 08:57 PM
  2. How would you cnc a corner joint
    By Rob Keeble in forum Programming, Troubleshooting, and Q&A
    Last Post: 09-27-2014, 10:57 AM
  3. Box Joint Jig
    By Dan Mooney in forum Jigs and Fixtures
    Last Post: 01-05-2012, 01:10 PM
  4. Finger joint Box
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 01-23-2010, 10:26 PM
  5. seeking name of joint
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 09-30-2009, 11:49 PM
