Results 1 to 10 of 11
Thread: How I solved my chipped veneer problem
    Constantine, MI
    7,890
    In my chancel furniture build thread I noted that I had gotten frustrated with chipping out of the veneer on my white oak plywood. I was getting clean cuts with the grain, and pretty good cuts across the grain where I could use the fence, but the angled cuts - that was another story. I surmised that I was not getting a rock solid guide through the blade and therefore was getting chip out. So, I started looking for a solution.
    I mentioned the fix in the other thread, but a certain bearded moderator that travels a lot insisted I should expound on it.
    The solution, for me - YMMV, was to clamp a straight edge along my line and use a bearing guided spiral router bit to clean up the cuts.
Name:	Down Spiral.jpg
    After getting the two parallel edges perfect, I placed the frame on top of the ply to mark out my angled cuts. Then, I used the TS to get close to the line.Click image for larger version.
Name:	Initial clamp up.jpg
ID:	28386Click image for larger version.
    DISCLAIMER - On all the other pieces that required these cuts I started with the ply and built the frame around it - the easier way for sure. However, this needed to be done in reverse because of the compound angles in this particular part of the build. I'll post pictures of that in the other thread in a few days.
    Then I clamp a strait edge along the line Click image for larger version.
Name:	Along the line.jpg
    Get everything clamped securly and do my routing
Name:	Guiide attached.jpg
ID:	28385Click image for larger version.
Name:	Clamped and ready.jpg
    The result is a clean edge and a snug fit. I did have to go back and make a few more passes to sneak up on it, but it was worth it having the nice clean fit.
ID:	28383Click image for larger version.
    www.wrworkshop.com
    Dec 2008
    falcon heights, minnesota
    5,609
    rennie, i've always kept it a bit simpler, i just use blue painters tape where i'm going to be cutting.
    benedictione omnes bene
    www.burroviejowoodworking.com
    13,439
    What a great tutorial Rennie, I'll add that to my list of how-tos. I've used the painter's tape as well, but still haven't gotten that clean of a cut.
    Thanks!
    Constantine, MI
    7,890
    Quote Originally Posted by Dan Noren View Post
    Thanks!
    The painter's tape trick did not work well for me. Most likely operator error.
    www.wrworkshop.com
    Dec 2008
    5,609
    that could be, and i think that also i was using a 60 tooth blade. you didn't say what type of blade you were using.
    Constantine, MI
    7,890
    Forrest WWII
    www.wrworkshop.com
    17,471
    Thanks rennie your paid up fer another year now i figured that if it worked for you others would like to see how you handled it.. and it can go in the tips and tutorial forum someday!! well done !
    37° 5'16.25"N 76°25'28.11"W
    193
    Rennie, Your already done now so I'm a bit late, but I use a Freud LU80R010 for sheet goods. The cut is amazing and with a fresh ZCI there is no chip on cross cuts, even with super thin borg veneer. It also leaves glass smooth crosscuts on solid stock like rails and stiles. For cabinet work I wouldn't be without mine!
    Mike
    Constantine, MI
    7,890
    Quote Originally Posted by M Toupin View Post
    Mike
    Hi Mike,
    When I could guide along the fence I was getting good results with my WWII. I don't think my blade is the problem as I'm getting great cross cuts. It was the angled cuts I was having problems with. I tried using the miter gauge and a sled, but neither was giving me the control I needed to cut a true line. I believe that is where I was running into trouble.
    Using the router gives me the control I needed.
    www.wrworkshop.com
    Southern Louisiana
    947
    great job rennie, thanks for sharing. that joint looks stupendous
    chris
  1. Bandsaw Dust Collection Problem Solved
    By glenn bradley in forum Off Topic Discussion
    Last Post: 09-17-2011, 08:36 PM
  2. Solved the New Grinder location problem
    By Bartee Lamar in forum General Woodworking Q&A
    Last Post: 01-04-2010, 03:37 AM
  3. New Ceramic Toishi..... Update.... Problem Solved!!
    Last Post: 11-13-2009, 04:59 AM
  4. Drill press problem solved
    By Dale Johnson in forum General Woodworking Q&A
    Last Post: 12-31-2008, 03:54 PM
  5. problem solved
    By Dave Kauffman in forum New Tools
    Last Post: 06-13-2008, 01:40 AM
