Results 1 to 6 of 6
Thread: Jointer Problems
    Jointer Problems
    I have an 8 inch Bridgewood Jointer that I purchased used a while ago. When I turn it on it starts up slow and takes about 20 seconds to get up to full speed. If I Face Joint a board and take more than a 1/32nd of a cut it bogs down. It is not the belt slipping. The motor actually slows and stops. Anyone have any ideas. Could the cord length to the outlet have anything to do with it? Do I need to replace the motor or is there anything else I can check out. I am going to sell this machine in the near future and I want it fully operational prior to selling.
    Greg
    greg, run pick-up a clamp on amp meter and check the amperage draw freewheelin` and loaded......that`ll tell you more than 150 internet guesses...tod
    Atlanta, Ga.
    26
    Greg...
    Ditto tod's comments! If.. it has come up to speed in the past.. if you are on a non-overloaded circuit ( too many tools drawing current at the same time or lengthy extention cord decreasing flow at end ).. if the belt is not slipping as you said it wasn't.. then the amp test should be your next step as it sounds as if the windings may have drawn near retirement age.
    Good luck...
    JT.. sarge
    The Heart of Dixie
    4,268
    Ditto the above comments. One other suggestion that may or may not be cheaper than a new motor, is a motor repair shop. I take all my old machine motors to a shop and have them repair them. Usually cheaper than a new motor and I trust they are right when they come back.
    Custom built boats and Kits
    It could also be the motor Capacitor. Like was mentioned take the motor to a motor repair shop and they can tell you if it's a problem.
    Atlanta, Ga.
    26
    Don is correct that the more likely culprit is the capacitor with what you described. What-ever, the small motor shop is sound to idenify and fix what ails...
    JT.. sarge
  1. help, big bowls, big problems
    Last Post: 10-13-2014, 01:26 PM
  2. Thicknesser problems
    By Bruce Thomas in forum General Woodworking Q&A
    Last Post: 09-22-2012, 11:22 AM
  3. youtube problems
    Last Post: 05-24-2010, 01:52 PM
