Results 1 to 5 of 5
Thread: Mitered Raised Panel Door
    Sep 2007
    Bloomington MN USA
    268
    Just got the bit for making the moldings yesterday late.Did a lot of checking out how to and what not to do and was all set to turn out my first mitered raised panel door with the new molding bit. The bit is a full 5 inches long.4" of the bit with bearing is above the table.
    I had to make up a fence to contain this tall bit. I used a Melamean shelf ripped down the center and then doubled up to contain the bit.
Name:	Fence for Molding Bit.jpg
    I then needed a safe way to make the passes necesary to make the moldings
    The push block does this quite well,It keeps presure on the working piece aginst the fence and table at the same time and pushes the work piece through the router bit.
Name:	Push Block For Molding Bit.jpg
    I took 2 or 3 passes at a meadiam speed (3 ) and the last pass at almost a (5) It came out nice and smooth.
Name:	Push Block with Molding.jpg
    Next is to cut all the miters and then the tounge & groove to give strength to the corners.
Name:	Finished Molding.jpg
    Hopefully the rest will come tomorrow. I was more then willing to go at it more to day but was getting to cold. As this morning my gas furnace in my shop decided to take the day off. Hope to get it fixed tomorrow. Used a small electric heeter today BRRRRR. -7 this morning. But when you get a new toy sometimes you just can't wait for the temp. Will let you know how the rest goes
    If you make a mistake it was part of the original plan!
    Alexandria, Virginia
    1,071
    Now that is a router bit Ron. Great fence and very nice results!
    I was looking at those bits in the new MLCS catalog. Looks like an interesting idea. Would like to see how you do your corners!
    17,472
    very nicly done ron well documented and great results from it..i too wouldlike to see how you got about your mitres,, thanks for the post
    Oct 2007
    Schenectady, NY
    912
    Cool !
    Great work Ron. Moulding looks great. I like the push block too-sturdy and safe. Looking forward to the finished product.
    Don Orr
    Woodturners make the World go ROUND
  1. Raised Panel Doors in SketchUp
    Last Post: 12-31-2012, 03:42 AM
  2. Raised panel closeout
    Last Post: 03-22-2012, 01:45 AM
  3. Raised Panel resized?
    Last Post: 01-16-2011, 04:27 PM
  4. raised panel tutorial, Table saw
    By Dan Noren in forum Tips and Tutorials
    Last Post: 05-08-2009, 05:27 PM
  5. Raised Panel Door
    By Sean Wright in forum Flatwork Project Showcase
    Last Post: 03-29-2007, 12:16 PM
