Results 1 to 10 of 16
Thread: Euro hinges
    Oct 2008
    1,357
    Euro hinges
    How much weight will euro hinges support? I've got a pantry that has 11 1/2" x 40" double doors and I need to mount 2" deep spice racks to the inside of each of the double doors. Should I use 3 hinges for this application? Will two do the job?
    ADDED information. The spice racks will be about 9"x18-20" tall
    Aloha,
    17,475
    3 hinges on 40"
    Oct 2008
    1,357
    Thanks for the quick reply Larry....
    Aloha,
    17,475
    built a pantry that had two 16" wide by 40" doors and that was what was told and did use,, still holding well.. as they say royal ifun doubt
    Oct 2008
    1,357
    When I got into WW I found myself "over building". I built some shelves once and the neighbor came over and took a look and ask if I was going to store engine block on them.
    Aloha,
    Dec 2008
    Portland, Oregon
    1,898
    Quote Originally Posted by Royall Clark View Post
    Hey you can never have enough engine storage
    Jesus was a Woodworker
    Catalunya
    4,632
    As I think that the only stupid question is the one that is not asked, I'd like to know, just to widen my ww knowledge what or how are euro hinges?
    I problably know them but not under that name, hence my question.
    Thanks
    Best regards,
    Toni
    Oct 2008
    1,357
    Toni, I think another name is concealed or hidden? Uses a 35mm hole to mount the hinge cup in and a screw on each side. Here is a picture, better than what I'm trying to saw!
    Aloha,
    Catalunya
    4,632
    Thanks Royall.
    As I thought I know them, thanks for posting the pic, now I know what you were talking about.
    Best regards,
    Toni
    Southern Louisiana
    947
    royall, i might go with 4 hinges on that application. i would use 3 without the spice racks. especially if this is a paying job.
    think of it this way, 1 year from now, the client calls and says, "hey those doors with the spice racks came off the cabinet. i need you to fix it"
    well the problem with that is, sure you could add a 4th hinge, but you drilled 3 holes probably top, bottom and center of the door. no good place to drill a 4th hole now. so what do you do? i guess you could add a 5th hinge.
    not sure what these hinges cost you, my wholesale cost was about 2 bucks a hinge. 4 bucks goes along way to make me feel better about a door holding up for a client.
    just my 2 cents, it's always possible the 3 hinges would hold fine.
    chris
  1. Euro's Worth more than a Euro
    By Jon Lanier in forum Lathe Project Showcase
    Last Post: 11-19-2008, 08:21 PM
  2. Euro hinges for beginners - part II
    Last Post: 10-06-2008, 06:01 AM
  3. Euro hinges for beginners - part I
    Last Post: 09-30-2008, 10:09 AM
  4. 2nd euro
    By Ed Nelson in forum Lathe Project Showcase
    Last Post: 07-06-2007, 11:08 PM
  5. Best jig for euro hinges
    By chris johnson in forum General Woodworking Q&A
    Last Post: 12-16-2006, 06:03 AM
