Results 1 to 10 of 10
Thread: 12345
    NH
    4,006
    12345
    12345
    Stupid hurts.
    Jul 2007
    Des Moines, IA
    854
    Chuck, you hit the correct answer. One is home made and mine cost about $35. My home made rig works very well. I am in the process of doing a tutorial for building one. I will post when it is done. I have never used a manufacturered rig and have only seen pics on websites of those. Here is the original thread that I started. http://familywoodworking.org/forums/...es+steel+snake
    30,017
    Aside from the purchased vs. shop-made aspect, the Monster arm mounts to the bed of the lathe instead of the tailstock. This does give it more flexibility in how it approaches the turned piece. I move the base around quite a bit when I'm turning a hollow form. If I start getting vibration during a cut, I find that often I can get rid of the problem by simply changing the location of the base, and thus the various angles in the "folds" of the arm.
    Aug 2008
    Reno, Nv
    3,632
    Wayne...if you can go any faster on that tutorial, I'll send you a sandwich. I have a couple of #2 morse tapers from pen turning spindles that went out of round and if you could factor that in...that could save some of us $$ since most of have some of those floating around. And yes...I'm holding my breath
    30,017
    Ok so what is the advantage of using one?
    I am tring to decide if I need/want one and rather to buy or make.
    The advantage to using one is that it makes hollowing MUCH easier, both physically and mentally. I wish you weren't on the other side of the continent...otherwise I'd invite you over to try one out and see how you liked it.
    As far as the "make vs. buy" decision, that's really up to you and your time/ability/money/patience. I bought mine because I didn't have an easy way to make one, and I'm pretty certain the one Randy makes is better than anything I would have put together. I also had the money at the time to pull the trigger, and liked the idea of helping to support Randy. In my mind, I justified the purchase by telling myself it would pay for itself after selling the first few hollow forms made with it.
    Dec 2008
    falcon heights, minnesota
    5,610
    this is the first time i've seen anything like this for turning. is it for people who have a bit of a time holding on to the tool?
    benedictione omnes bene
    www.burroviejowoodworking.com
    30,017
    Dan, it's for hollowing out the inside of a hollow form, or something like a deep vase. It can be done with handheld tools, but holding the tool in a captive rigs makes it much easier.
    Here are a couple videos showing one in action:
    http://www.youtube.com/watch?v=YA--j...eature=channel
    http://www.youtube.com/watch?v=k--ap...eature=channel
    Aug 2008
    Reno, Nv
    3,632
    Why can't we hire the Army to make a laser to do the hollowing and forget the chisel? We don't need no stinking sharp things
    To the point Chuck, that's what the laser is for, and if used correctly, Stu can explain that part, it can help with thickness as well. I think Stu built his and added the laser 'cause he is all that and a bag of chips...really...he is, and if I had that skill, I'd make videos too!!! He has a link on Youtube about his rig and death beam attachment.
    Dec 2008
    5,610
    that answers my question about it to a t. i could also see where it would be handy with larger vessells, and controlling vibration/chatter as well.
    Goodland, Kansas
    4,834
    Chuck I have the monster and the laser. It is a fine rig and as Vaughn said it is sure easier on the old body. I can turn for several hours with this as with a hand held one maybe a hour before arthur kicks in. I bought mine because of the fact if I made homemade tools I would never get any turning done.
    Bernie W.
  1. 12345
    By Chuck Thoits in forum Off Topic Discussion
    Last Post: 04-26-2009, 05:23 PM
  2. 12345
    By Chuck Thoits in forum Jigs and Fixtures
    Last Post: 03-05-2009, 11:31 PM
  3. 12345
    By Chuck Thoits in forum Turning Tool Questions and Show & Tell
    Last Post: 02-11-2009, 09:27 AM
  4. 12345
    Last Post: 02-03-2009, 02:05 AM
  5. 12345
    Last Post: 02-03-2009, 12:50 AM
