Results 1 to 7 of 7
Thread: More endless finishing questions
    Aug 2008
    Reno, Nv
    3,632
    What can we mix with what? I like the depth of the wipe-on poly, but friction polish has a great shine. Can arm-r-seal be used over different base finishes? Should shellac be used with anything else as a top/base finish? I'd really like to hear what mixes are working. I'm doing a pepper mill now that is going to a fundraiser and really want the finish perfect. What are some good combo's that work...please show what ya know too
    Dec 2008
    falcon heights, minnesota
    5,609
    for my pens and pencils, i've used a mix of 1/3 each of shellac, boiled linseed oil, and denatured alcohol, applied and buffed out while on the lathe. i think you could go with some sort of wax over it to add more protection.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Goodland, Kansas
    4,834
    Jim I basically use the General Finishes but first put on Seal-A-Cell (one coat) then top that with Arm-R-Seal. I also use Minwax Antique Oil. That is what I use on my salt/peppermills. It is not a real glossy shine like gloss poly or gloss lacquer. Another one that will give you the oil finish with a great gloss is Waterlox. If I want a oil finish with a gloss look I use Waterlox High gloss. I am attaching a picture of a communion bowl I did for our priest done in Waterlox High Gloss. To answer your question I have put poly over Antique oil after it has dried a few days but have never tried it friction polishes. I don't use friction polish on much of anything any more because like on peppermills it just won't last. Gives a good shine but anything handled much it doesn't last long.
    Attached Thumbnails Attached Thumbnails Olive Wood Bowl 1.jpg   Olive Wood Bowl 2.jpg
    Bernie W.
    Hardinsburg, KY
    277
    The only thing you can't do is put lacquer over other finishes. Most anything else you can do. Shellac will seal an oil based product so that you can top coat with water based products. I've used lacquer as a sealer/base coat for nearly every other finish on the market. You just can't use other products and then use lacquer since it tends to go through all other layers to get to the wood.
    30,015
    Quote Originally Posted by Doug Miller View Post
    Doug, I've had good success spraying lacquer over wipe-on finishes like Antique Oil or "tung oil" finishes, and also over sprayed shellac. I give the wipe-on stuff a few days to cure, then apply multiple coats of lacquer. Let that cure for a few days, and buff it out. Haven't had any problems with that combination yet.
    Aug 2008
    Reno, Nv
    3,632
    Dan, are you getting your shellac in flakes or pre-mixed? The flakes will raise a whole different bag-o-worms but I want to get into those to.
    Goodland, Kansas
    4,834
    Jim I mix my shellac from the flakes and Denatured Alcohol. You can make whatever cut you want from 1 to 3 lb cut.
    Bernie W.
  1. Finishing Questions
    By Paul Douglass in forum Finishing School
    Last Post: 05-12-2014, 06:15 PM
  2. A Variety of Basic Finishing Questions
    By Cynthia White in forum Finishing School
    Last Post: 04-12-2011, 07:29 PM
  3. General Kitchen Cabinet Finishing Questions
    Last Post: 06-20-2010, 04:18 PM
  4. More finishing questions
    By Dan Mosley in forum Lathe Project Showcase
    Last Post: 02-22-2010, 05:15 AM
  5. Finishing questions on bowls
    Last Post: 12-06-2008, 04:04 PM
