Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 58
Thread: Dog Gate - Intallment 4 - Getting Closer to Done
    OK, just to keep from getting harassed too much, I figure I'll post a few pics of my ongoing dog gate project...a fairly rare trip into Flatland for me.
    If you missed it, here's the backstory on the gate. After some local lumber shopping. I decided to use kiln dried pine from the Borg. I priced poplar as a cheap hardwood, but couldn't justify $250 for materials alone. Lumber prices are outrageous in LA. I picked up two 16 foot long 2x6s for about $40 instead.
    I cut the boards in half and milled them as 8' pieces, to cut down on loss from planer snipe. It took some rearranging in the shop to accommodate working with long lumber, but I got it jointed and planed, ending up with 1 1/8" thick stock. Little thinner than I was originally hoping for, but no biggie.
Name:	Dog Gate 01 - 800.jpg
    One of the four boards had a bend in it that I didn't flatten. (I didn't have enough wood to do that and maintain thickness.) I figured I could use it on the shorter pieces.
Name:	Dog Gate 02 - 800.jpg
    Instead of dragging out the chop saw for my rough crosscuts, I used the little cordless circular saw that came with a set. I also used the same little saw in the parking lot of Home Depot to cut the 16' boards in half to take home in my little Ranger pickup. I decided to try using one of my clamp-on straightedges as a guide. Worked pretty well.
Name:	Dog Gate 03 - 800.jpg
    And the end result after rough cutting to length...
Name:	Dog Gate 04 - 800.jpg
    Next, it was time to cut things to finished lengths. Since the two long stiles were longer than I could cut with stop blocks on either my miter gauge or crosscut sled, I clamped the two together and cut them to length...I wanted them to be exactly the same size. The exact length isn't important, but they have to match exactly.
Name:	Dog Gate 05 - 800.jpg
ID:	28570 Click image for larger version.
Name:	Dog Gate 06 - 800.jpg
    The shorter stiles and rails were easy to cut to exact (and matching) lengths with the miter gauge. A few more crosscuts, and I had the basic frame parts cut...
Name:	Dog Gate 07 - 800.jpg
    Then it was time to drag out the mortiser. Did you know that a Johnson Paste Wax can is the same height as the table on a Shop Fox mortiser? Me neither.
Name:	Dog Gate 08 - 800.jpg
    And next, the tenons. I have a block of UHMD plastic that's exactly 1 inch thick. I use it when I want a fence-side stop block when using the miter gauge. I just add an inch to whatever length I need, and dial it in on the Incra fence. Since these tenons were going to be longer than my dado stack is wide, I set the fence for my maximum tenon length, and took out the waste in two passes per face.
Name:	Dog Gate 09 - 800.jpg
ID:	28574 Click image for larger version.
Name:	Dog Gate 10 - 800.jpg
    More in the next post...
    Continued...
    Before too long, I had the mortises and tenons all cut.
Name:	Dog Gate 11 - 800.jpg
    The tenons show that my dado stack is not perfectly flat...you can see where the outside cutters went a bit deeper. No problem, they won't be seen.
Name:	Dog Gate 12 - 800.jpg
    Did a little cleanup by hand. (Tod...I finally got a chance to use the Two Cherries chisels. After tuning them up on the Tormek, they're sweet.)
Name:	Dog Gate 16 - 800.jpg
    Still not smooth inside by any means, but I'll be using epoxy, so I'm not worried about little gaps that won't be seen. The fit is good and firm.
Name:	Dog Gate 13 - 800.jpg
    The first dry fit...
Name:	Dog Gate 14 - 800.jpg
ID:	28580 Click image for larger version.
Name:	Dog Gate 15 - 800.jpg
    Then I fit the arched piece and the short stiles. I cut them to be a tight friction fit. They'll be held in place with biscuits and splines.
Name:	Dog Gate 18 - 800.jpg
    I'll post more progress pics when I get a bit more time. For now, this ought to keep the pirates at bay for a day or so.
    Nice looking work, looks like you have not forgotten how to do flat work
    careful there vaughn you just might start lookin` at spinny stuff as a way to make flatwork more profitable instead of a craft of it`s own
    Return to the light, return to the light . . . That is looking really good there, Vaughn. Thanks for all the pics. That should silence your assailants for a while .
    Inside the Beltway
    2,666
    Dang, Vaughn,
    We have almost exactly the same tools, but my mortises and tenons don't fit together like that! Nice work!
    Now, who'll bet that he starts having spinny withdrawals sometime between now and glueup?
    Bill
    Bill
    round gate handles?
    Constantine, MI
    7,891
    You know Vaughn, for a spinny guy you do nice work.
    www.wrworkshop.com
    Jul 2007
    DSM, IA
    5,719
    I don't know...kinda looks like a dog could go right thru this gate...I'd stick to the lathe if I was you Vaughn.
    Don't listen to those flatworkers...get back to spinning wood quick before it's to late.
    My Website
    3,134
    Did you know that a Johnson Paste Wax can is the same height as the table on a Shop Fox mortiser? Thanks Vaughn I needed to know that as I have both the right mortiser & right can of wax.
  1. Getting Closer! - Received!!!
    By Bill Arnold in forum New Systems and Builds
    Last Post: 02-17-2015, 06:33 PM
  2. closer!
    By hu lowery in forum Lathe Project Showcase
    Last Post: 05-17-2013, 02:39 PM
  3. Another step closer
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 01-10-2013, 03:40 AM
  4. Need to Pay Closer Attention
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 05-13-2010, 01:04 AM
  5. Ain't there yet, but getting closer to Alfredo
    By Chuck Ellis in forum Lathe Project Showcase
    Last Post: 03-12-2009, 08:31 PM
