Results 1 to 10 of 10
Thread: Mission Taboret - first sketchup model, please critique
    Topeka KS
    118
    this is a mission style taboret table that i designed taking some cues from a couple tables i saw in several woodworking books, i cant remember exactly which ones though
    anyways this is my first complete sketchup model so i hoping to get some advice on anything i should do differently.
    the only thing im so-so on is the screws (bolts?) that hold the top on, first i couldnt figure out how to make a screw head so i did a bolt and second i used a texture for the threads because i couldnt figure out how to make them otherwise
    anyways eventually id like to build a real version of this table
    mission_taboret.skp
    Als ik kan
    17,470
    i havnt played in sketchup for the furniture part of it but i can say this you got the QS oak pattern down well and the style kinda looks like g&G some,,dave richards on here can help you on gettin the threads and such..and i like your avatar as well thats clever
    Dec 2008
    falcon heights, minnesota
    5,609
    a great first effort! it looks like it would follow along the lines of charles limbert. sort of a stickley meets elegance, rather than the stickley meets japan with g&g furniture. personally, i would have gone with figure 8 table irons, rather than screws, as they allow more wood movement. used them on all my tables, and not a crack yet, over 5 years of temps and humidity all over the scale. keep up the good work! sketchup is fun for working out what i would call evil thought projects.
    benedictione omnes bene
    www.burroviejowoodworking.com
    17,470
    is that done in pro or the free version?
    Topeka KS
    118
    im using the pro version of 7
    Als ik kan
    Topeka KS
    118
    Quote Originally Posted by Dan Noren View Post
    thanks dan, i was concerned about movement so i enlarged the holes for the screws to go through and used a washer head bolt. i may redo it with the figure 8s as i think where i have the holes drilled for screws on the sides may be a weak point. where would you locate the figure 8s if you were doing a project like this? also should i do the same for the bottom shelf? right now its basically free floating, not sure if thats a good idea or not
    Als ik kan
    Dec 2008
    5,609
    what i've done with my tables, is to take a .5" (that's half inch larry) forstner bit, and made a round mortise, offset enough to create an opening for the waist of the table iron. nice thing is that it gives you a centered mark for predrilling for the screw. then predrill for screws in the underside of the table. if the table has an apron, i would attach to the apron, if cross members like your example, to the cross members. i'm including an example of how i used them to attach the top of the bed side tables i made. hope all this helps.
    Lima, NY
    53
    Mike, I like the simplicity of your table. (although we all know that it's not a simple table to build) A good choice of wood will make this table stand out even more. I think that the figure 8 table top fasteners would be a better choice then screws through the legs.
    Your Sketchup skills are doing great. I noticed that you have made each part a component which is very good. I wouldn't have made this model any differently myself. Here are a couple of renderings that I did of your table.
    Attached Thumbnails Attached Thumbnails table-1a.jpg   table-2a.jpg   table-3a.jpg
    SE Minnesota
    2,524
    Nice model. I recognize that oak material.
    30,008
    Cool table, Mike. I like the lapped leg joints. (It's cool being able to dissect it and move the parts around with SketchUp.)
  1. A SketchUp Model From a Photo
    Last Post: 11-15-2011, 12:31 PM
  2. Model a floor plan from an image in sketchup
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 10-19-2010, 02:36 PM
  3. Mission style dresser - latest design, please critique!
    By Mike Gager in forum Designs, Plans and Sketches
    Last Post: 02-21-2009, 12:50 AM
  4. A SketchUp Model Rendered
    Last Post: 10-17-2007, 02:23 AM
  5. Animating Your SketchUp Model
    Last Post: 09-13-2007, 05:24 PM
