Results 1 to 3 of 3
Thread: Bench grinder to drive flexible shaft?
    I would like to use the spindle of my bench grinder to drive a flexible shaft for a pneumatic drum/ball sander. Can I do this? How do I go about it? I've seen some motors with drill chucks installed on one or both sides ...
    11,825
    Yep, works that way. You will have to sacrifice a grinding wheel though.
    An arbor adapter (cheap) is probably an easier way to go than the drill chuch bit.
    Honolulu, Hawaii
    1,103
    Leigh, I'm sure it can be done. I would question the flex-shaft for the speed (3450 rpm's) of the grinder. I have an old shaft (pix later if needed) that attaches to a plain shaft motor, but mine runs @ 1725 rpm's. I never tried it faster.
    Another thing would be the attachment of the adaptor to the grinder shaft. The adaptor bore will have to be precise in the ID to fit properly on the THREADS of the grinder shaft. Most flex-shaft hubs have set screws to hold to the motor shaft. These are going to damage the grinder shaft threads. And, if the ID is any over-size, the hub will be off center, because of the set screws, and cause vibration.
    Why not just use an extra motor whose shaft size fits the flex-shaft hob (adaptor) correctly and the motor shaft should have a flat for the setscrews to seat on. Then you keep your grinder free to do what it was intended to do, with wheels on it, instead of a flex-shaft.
    Just my opinion.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
  1. Steel Shaft vs Carbon Fiber Shaft
    Last Post: 02-14-2014, 07:00 PM
  2. Bench Grinder Advice
    Last Post: 11-19-2011, 11:35 PM
  3. Cup grinding wheels in a bench grinder?
    By Eric Roberts in forum Old Iron
    Last Post: 09-08-2010, 03:58 PM
  4. 8" Bench grinder advice
    By Drew Watson in forum New Tools
    Last Post: 12-14-2009, 07:41 AM
  5. Delta 6 inch variable speed bench grinder - SOLD
    By ken werner in forum Old Ads
    Last Post: 01-26-2008, 12:54 PM
