Results 1 to 10 of 12
Thread: Another point of veiw...
    17,470
    Sep 2007
    St. Louis, MO
    583
    Man, it's hard to know who to believe. I agree with his general sentiment that we should pursue our local resources, but most experts believe that, even if we sucked up all of the oil under U.S. dirt, it would be enough to feed our consumption for a year and a half. And it would take nearly a decade to get any into our gas tanks should we start drilling today.
    I'm not totally convinced about the environmental friendliness of drilling either, though i'm not as doomsday about it as a lot of folks. Given the track record, bad things can and will happen.
    Then there's the whole global warming issue.
    Not that i'm pushing one way or another, but the oil industry, the global economy, and rising temperatures have given a lot of people reason to look into alternatives.
    17,470
    Sep 2007
    Central (upstate) NY
    1,457
    A physicist that I respect on a scientific computing mail-list, R. G. Brown, has communicated in an off-topic thread that nuclear will only last so long also due to worldwide resources of fissile materials, etc. Thus nuclear is not a permanent answer.
    Now moving to my opinion, those fissile materials will undergo fission and release energy whether they are in a reactor powerplant or in the ground somewhere, so we may as well use them.
    Also my opinion, there seems to be an exclusive focus on greenhouse gases leading to increased temperature climate change. I wonder how much two other factors contribute to this phenomenon. First, we as human society, through our record usage of energy are releasing a record amount of heat into the planetary system since not even the best Baldor motor is 100% efficient. Every time we use some sort of energy using device we are bleeding heat into the environment. Second, with more and more roads and parking lots being built daily, we are slowly transforming the planet closer and closer to a black-body absorber. It seems to me (meaning I am not looking at hard data as I type this, nor have seen such hard data ever at all) that asphalt does a much better job of absorbing heat than any gas, greenhouse or not.
    Just my two cents.
    11,825
    There is so much information/misinformation going around, I don't know what to believe.
    One article I read several months ago said there are two giant underground coal mine fires, one in Russia, the other in China, that emit more CO2 and other noxious gasses into the air than all other factors in the world combined.
    If true, will my trading off my Dodge truck for a Prius help save the planet?
    (that's rhetorical, folks.)
    Jul 2007
    DSM, IA
    5,719
    My Website
    Inside the Beltway
    2,666
    deleted at Larry's request
    11,825
    I agree Frank. I live my life trying to be good to old mother earth, hope I'm helping, probably hurting her some too.
    BTW isn't there a coal mine in the US on fire too? I know there are a few tire pile fires that have been buring for quite some time right?
    There are several coal mine fires in the U.S. But the magnitude of the Russian and China fires dwarf what is in the U.S. None good but those two are, according to the reports, incredibly large.
    Inside the Beltway
    2,666
    Inside the Beltway
    2,666
    Deleted at Larry's request
  1. Eight Point
    Last Post: 06-22-2013, 01:40 AM
  2. Round-Point Tool
    By Cody Colston in forum Turning Tool Questions and Show & Tell
    Last Post: 11-22-2008, 04:05 PM
  3. Point of Use Water Heater
    By Rob Bodenschatz in forum Carpentry and Construction
    Last Post: 05-12-2007, 05:07 PM
  4. Brad point bits
    By Jeff Miller in forum General Woodworking Q&A
    Last Post: 05-10-2007, 01:22 PM
