Results 1 to 8 of 8
Thread: sanding veneer...
    Hedgesville,WV
    158
    sanding veneer...
    I tried 180 Gr on a spare piece( ..actually a piece I screwed up )... and I didn't like the results.it didn't show the flame afterwards..I'm using figured mahogany veneer for the drawer fronts/door panels on my daughters chest of drawers(maple).
    ...do you folks usually sand your veneer before staining? Thanks...
    "Treat everyone equally,keep your word, and overlook peoples' mistakes...you'll make plenty yourself "..... spoken to me by a much wiser man than I.
    yup you gotta sand it.......hit it with spirits to look-see after sanding.
    17,471
    hey mr Tod on the tape areas, after i hit with spirts it looks good but when dry looks like some reisdue showun up ,,its sanded to 180 now and will finish it off with 220 if need be
    Waterford, MI
    773
    I dont know why this should be so but I notice a big difference with 180 grit (and 220) between garnet (redish/orange) and aluminum oxide (tan) sandpaper. To me, the surface after garnet looks much nicer but a lot of what's available at the big box stores is AO. What kind are you using?
    810
    Hedgesville,WV
    158
    Quote Originally Posted by Doug Shepard View Post
    yep, it's AO... maybe I should look for some Garnett..
    Villa Park, CA
    1,407
    I agree with Tod. Mineral spirits sometime take a while to evaporate so I'll use lacquer thinner or alcohol if I want a quicker look - but look fast because you'll only see it when you wipe it on. It evaporates quickly.
    Mike
    Ancora imparo
    17,471
    mike what grit do you sand to
  1. PSA veneer on pine
    Last Post: 10-10-2012, 05:41 PM
  2. PSA veneer on glass
    Last Post: 01-14-2012, 12:44 AM
  3. Salvaging veneer
    By Steve Klein in forum Finishing School
    Last Post: 05-08-2009, 11:33 PM
  4. Ironing Veneer
    By Bill Arnold in forum General Woodworking Q&A
    Last Post: 09-23-2007, 11:52 PM
