Results 1 to 2 of 2
Thread: "original jimmy jig"
    Jan 2009
    I live in Denton, Texas and ranched at Schulenburg, Texas.
    116
    I was googling something and this "original jimmy jig" came up. The idea of the entire saw being incorporated into a sliding table seems very sensible. Does anyone have an exposure to it. They want $15 for a download; I really don't have enuf info to decide if it's worth the "gamble".
    What I am interested in is a "jig" to let me build horse stall doors with my tablesaw. I need six dutch doors 48" x 84". The bottom door will be 48 x48 and the top space the rest. The door will be two laminated perpendicular T-111 panels recycled from the barn. The two panels and 2 sheets of 26 gage sheet metal will be laminated into a single 4-layered panel; then they will be framed into a metal frame hinged to the metal door jamb. I will try to use a construction adhesive like PowerGrab for the lamination. Ideally, I need to rip my panels to fit at each stage of construction. It was much clearer in my mind before I described it. If you have an idea that might help; please, put it in reply. Thanking you in advance for all efforts.
    Ray Gerdes in beautiful Texas
    While the Jimmy Jig was a very good idea ( and I still like it ) byt the time you get all the pieces together and then add your time inot assembling it you're already done with you're project. If you plan on doing a lot of work then it certainly is worht pursuing.
    Personally, I think you'd be better off buidling a straight edge guide and cutting your pieces as needed. All you need is a sheet of hardboard and a sheet of ply.
    Do a google for circular saw guide and pick whatever one you think works best mate.
    http://www.popularmechanics.com/home...s/4283497.html
    パトリック
    daiku woodworking
    ^deshi^
    neoshed
  1. SIMPLE JIG! turns a "bowl" on "tablesaw"!
    By steve kelly in forum Carving
    Last Post: 11-01-2015, 03:21 PM
  2. "Crime Doesn't Pay" or "No Good Deed Goes Unpunished" ?
    Last Post: 11-21-2013, 05:57 PM
  3. Thompson "V" Versus "U" Bowl Gouges
    By Mike Turner in forum General Woodturning Q&A
    Last Post: 06-25-2013, 01:46 AM
  4. Original K-body 24" sale @ Woodcraft
    Last Post: 12-10-2008, 10:23 PM
  5. "Cording" the "Cordless" drill
    Last Post: 10-01-2008, 03:52 AM
