Results 1 to 5 of 5
Thread: A question for laser owners
    lutefisk capitol, USA
    485
    Does anyone here that has a laser setup have the capability to cut and engrave 1/4" 4130 steel? There is a person in New York looking to get some work done. PM me if you are interested. Thanks.
    Dale
    Rio Rancho, NM
    1,417
    No, Dale. Unless a laser is HUGE and has megawatts, it won't cut steel. It might engrave the steel, but most engraving on metal is done with a "toner"-like powder called Cermark, which is bonded to the metal by the heat of the laser beam -- and wears off eventually. Cutting that thickness of steel is best done by some other method--I suspect that no individual owns a laser that would do that job.
    Nancy Laird
    dandnspecialties@msn.com
    Yup... for 1/4" steel you probably want a plasma cutter. It slices through steel like it's butter.
    as far as engraving goes, I'm not really sure on that one.
    -J
    dale,
    fast cnc cutting (read cheap) is with plasma.
    accurate cutting or engraving is waterjet.
    485
    That's kind of what I thought. Can't beat a waterjet for cutting, the engraving probably could be done on a cnc router. Just trying to help the guy out. Thanks for the replys.
    Dale
  1. IBox owners! Got a question
    By Carol Reed in forum General Woodworking Q&A
    Last Post: 10-10-2012, 10:29 PM
  2. Question for the MOD's or owners
    Last Post: 12-30-2011, 11:16 PM
  3. G0690 / G06901 Owners - A Fence Question
    Last Post: 12-18-2011, 03:59 PM
  4. Question for Delta owners
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 02-27-2009, 05:22 PM
  5. Question for Delta owners
    Last Post: 06-29-2007, 02:06 AM
