Results 1 to 9 of 9
Thread: sliding cabinet doors
    Southern Louisiana
    947
    anyone ever install sliding cab doors, like on many of the popular media consoles today. where you have 2 doors, both on tracks and one slides behind the other. also seen these on some buffets.
    if so, did you use hardware for this application or did you make your own guide system?
    i'd like to put this kind of door on my media console i am presently designing but before I commit to them I wanna know what kind of experiences other have had with them. i see rockler has two different options for hardware you can puchase, one much more expensive than the other. here is a link
    http://www.rockler.com/product.cfm?page=10878
    http://www.rockler.com/product.cfm?page=2280
    any help or advice is appreciated
    thanks
    chris
    Chris, Rockler has more choices.
    I have made some like this Rockler Hardwood Track out of maple and white oak.
    Much cheaper here Bob Vila for the product.
    They also have Plastic .
    Just outside Sacramento
    2
    Frank Pellow made a nice cabinet with sliding doors. He's been on this forum before, not sure if he still hangs out here. Might try a search.
    Odessa, Tx
    1,813
    I always made my own with a router. I even made one where I cut the bottom grooves a little deeper and placed a strip of HDPE in the bottom tracks to improve the sliding quality because the doors were heavier than normal, and it worked well. Rout the grooves for the top of the doors deeper so you can insert the door into that slot first, and then drop it into the bottom slot. If you want to make it where the door can't be removed, then slide each door to one end and insert a filler strip (that is the thickness of the additional groove depth) in the top grooves and then slide them to the other end and do the same to that half. If you want it permanent, glue them in, but otherwise fasten them with a small brass or steel screw in a couple of places so they can be removed in case you want to take the doors out.
    here`s a pic of some i cut on the saw.
    http://www.todevans.com/todevans/sec...SectionID=1543
    new york city burbs
    10,188
    nice website tod, great stuff. wow.
    Southern Louisiana
    947
    thanks robert, good links there
    ken, i will have to search for that, frank still hangs around, he is just at pellow's camp pretty often, no internet out there.
    norman, those are good ideas, good info. thanks alot
    thanks tod, any info on how you made them.....nice headboard
    Quote Originally Posted by Chris Mire View Post
    just cut `em on the saw chris.....wooden tracks too.
    make the top track and tongue 1/4"-3/8" deeper than the lower.
    you need to remember to allow for the added tongue length when you assemble the doors or your rails will look odd.
    Southern Louisiana
    947
    thanks tod, i guess i was thinking it was more complicated, i understand what you're sayin.
    thanks
    chris
  1. 3hp 10 " cabinet saw and sliding table
    By Rich Soby in forum Classified Ads
    Last Post: 02-09-2016, 10:24 AM
  2. sliding closet doors, where can I find hardware
    Last Post: 11-02-2011, 11:39 AM
  3. Wood Sliding Bypass Doors?
    By Allen Bookout in forum General Woodworking Q&A
    Last Post: 05-03-2007, 01:03 PM
  4. Ideas for vertical sliding panels in cabinet?
    By Dan Forman in forum General Woodworking Q&A
    Last Post: 03-20-2007, 07:08 PM
