Results 1 to 10 of 13
Thread: DC Piping
    Floydada, Tx
    1,941
    DC Piping
    Spiral pipe? I am not sure exactly where to find it or what it really is. Is is something that can be found in a HVAC supply house? I am ready to step up from useing a short hose and going from machine to machine with the DC. Sewer pipe in larger size can only found in the cities(hour plus drive on way) or going thru local plumbers that want way to much for it. So I am looking for alternatives to PVC.
    Greater Toronto Area
    10
    Suppliers to the HVAC firms is one place.
    I know Lindab is a company that makes them. I think JET sells them as well.
    They're out there. If you go into many commercial/industrial establishments, it is what they use often for their forced air ducting or exaust.
    I used 4 inch PVC for my DC collection system and I did not understand what was really meant by "Static Pressure" of plastic piping vs. metal piping. Thankfully I have a small shop with short runs, as I realize now that static pressure is like having the inside walls of the ducts wet insofar as what they could pull vs the same size in metal spiral duct.
    The other advantage is there should not be grounding issues with metal pipe, whereas plastic, although they say that in a home hobbiest using less than 5HP DC there should be no concern, I don't want to be the one in a million to find out otherwise, so I grounded my piping inside and out.
    The cost for me of the PVC vs Spiral was $600 vs $$750. I honestly decided on PVC for simplicity of implementation and the fact I could run down to Home Depot and get joints and connectors as I went along, rather than have to deal with returning unused components or acquiring additional components at greater expense and delay using spiral.
    Here in Canada, the only source I found within reasonable distance of the grreater Toronto area were all wholesalers and have a list price for suckers and a contractors price which is 40 to 60% less if you can get chummy with them and get them to agree to sell it to you at that price. I actually did get one of them to agree to 50%-60% discount on the initial order.
    Do your homework as to what you need and have a list of what you want to buy. Lee Valley has an excellent self cleaning metal blast gate that was cheaper than the non-self-cleaning ones sold anywhere else I found which is what I used for mine.
    Good Luck...Kevin
    Waterford, MI
    773
    I'm on the exact same quest at the moment and frankly I'm finding the duct research harder than the time I spent researching the cyclone DC. I'm heavily leaning toward going with the spiral duct but who knows at this point. One thing I've noticed on Bill Pentz site is that the type with laser welded seams is much better than the stuff a lot of companies make so I've been watching for this on my web-surfing. Here's a excerpt from Bill Pentz' site:
    Here are the Hazen/Williams friction factors for various duct types (a higher C number is better).
    Corrugated steel duct= 60
    Spiral Duct = 90-100
    Laser Welded Steel Duct = 110-125
    3-PVC Duct = 146
    Bill's site also had a recommendation and link to these guys:
    http://www.ductincorporated.com/companyinfo.htm
    And these also seem to be using laser welded duct
    http://www.nordfab.com/pipe.cfm
    http://www.monroemetal.com/products/...?category_id=1
    Haven't investigated the prices yet from any of these, but I hear the Nordfab stuff is pretty pricey.
    Northwest Indiana
    104
    This is where I bought my spiral pipe from best deal I could fine. I payed 1.90ft for pipe and 2.17ea. for the couplings. Shipping came out to about another .80 a foot. With 12 couplings http://www.spiralmfg.com. I bought blast gates for Lee Valley the self cleaning type they work great.. And elbows and Wye's from http://www.kencraftcompany.com/Dustindex.htm
    Hope it helps,Russ
    There is unrest in the forest,There is trouble with the trees
    For the maples want more sunlight,And the oaks ignore their plea's. N.Peart
    Floydada, Tx
    1,941
    I looked at home depot for 6" pvc, but the dont not carry it. At this point if I have to order it it looks like it will be close to the same price. Laser welded pipe from what I have seen is way to much funds, at least till I win the lottery. . Thanks for the input. When I do decide on a final setup pics will be posted.
    2,784
    Al, on the 6" PVC, you won't find it at HD or Lowes. I've heard from some that a few Menards carry it. If you are interested in using it, you need to find a wholesale plumbing supply house. Ask a couple plumbers in your area where they buy their supplies. I found a couple places that could get it, and one that normally had it but was out, and one that had it in stock, but didn't know what it was called! Ask for thin wall gravity fed sewer and drain pipe, 6". The ATSM numbers didn't seem to make much sense to anyone I talked to. I bought 2 10' lengths at 1.86 per foot, then the last 3 they sold to me for almost half that! It was 10.11 each including tax (8.25%). McMaster Carr has the best price for the 6/6/6 wyes, and the 45 els. If you use any 4", again better priced there. I got 6/6/4 wyes at Lowes for just under 19.00 each. Go figure, they have some fittings, but no pipe! Maybe the same fittings fit on the green S&D pipe that they carry, never tried to fit it together. I got my 6" flex from Woodworker's Supply. Best price I found. Waiting on the 4" to come off back order. With a little use of a hair dryer, it fits on the 6" PVC nice and tight. And for those of you with MiniMax and maybe other, dust inlets that are metric...The 4 inch thin wall PVC is a tight tight fit over that, then you can plumb with the pipe and fittings! I didn't even feel that I needed to seal the joint, but I did silicone the edge anyway. I'm guessing the other units have the same outlet for DC hookup that my E16 has. Hope this helps!. Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    The Heart of Dixie
    4,265
    I was going to say what Jim said. So rather than repeat it I will just second it, find a plumbing supply house.
    I have never worked with spiral duct but I would imagine that PVC would be much easier to work with and simpler to make changes to in the future. Once I finally do get to do mine that is what I am going with.
    Custom built boats and Kits
    Any decent sized sheet metal shop fabs spiral ducting. Yellow pages, plumbing heating and air conditioning.
    Montclair, NJ
    95
    Al, I'm in NJ. I use Dunphy and Associates Supply Co. (Dasco). They are in Edison and Whippany. And I'd definitely recommend the spiral pipe route, I love mine.
    Waterford, MI
    773
    Just curious as to whether anyone that's using spriral has used any of this stuff (or equivalent) for noise reduction, and if so how much difference did it make?
    http://www.medhvac.com/productslist....90&Selection=2
  1. Working on my dust collection piping
    Last Post: 03-28-2012, 08:25 PM
  2. Airline Piping Diagram for Compressor Lines
    Last Post: 09-15-2009, 06:55 PM
  3. Dust Collection piping installation.
    By Bartee Lamar in forum General Woodworking Q&A
    Last Post: 03-16-2008, 05:29 AM
