Kenneth Lasota
- s. Barrington,IL.
Frank, what makes you think the legs are "Stamped Steel"
They look welded to me.
Neither are the legs on the Oneway lathes or the bigger Robust lathe, but I've not seen anyone who said they wish their Oneway had cast iron legs. I suspect they are comparably heavy, and actually less flexible than the cast iron. The Robust and Oneway lathes are built with no expense spared (obviously, based on the price tag). I suspect if cast iron was a better material, it would have been used in these lathes.Just appearance, they look it to me. Sure not heavy cast iron.
