Results 1 to 9 of 9
Thread: 12345
    NH
    4,005
    12345
    12345
    Stupid hurts.
    Honolulu, Hawaii
    1,103
    Yet another Chuck ?
    Chuck,
    1. Is the adaptor face contacting the shoulder of the spindle?
    If the adaptor doesn't sit flush against the spindle shoulder, it is depending on the threads to center it. These won't do it. Perhaps the adaptor internal threads are not recessed enough and the thread bottoms on the end of spindle threads and won't go far enough to seat the adaptor against the spindle shoulder.
    2. Is the adaptor seated completely in the chuck threads?
    Here again, there may be a case of the threads interfering with the adaptor seating fully against the back of the chuck. These flat shoulders are what give the chuck its alignment.
    Hope this helps.
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    30,017
    When I got my 3520 I got two new Nova adaptors, and one of the two had a considerable amount of runout. I ended up returning it for replacement. If you've already checked the two things Tony recommends, then I think I'd contact the seller and tell them what you're seeing.
    11,832
    I like to use nylon washers behind the chuck to facilitate removal. With my mini-chuck there is no problem and all runs true. But, with my Barracuda 4 I cannot use the washers. The 'cudda must be screwed all the way back to seat square. With washers it is wobble city. Are you using washers?
    Drums, PA
    292
    Out of 5 chucks, I found one adapter that was bad. It was the only third party adapter I bought. I was trying to save a few bucks. Lesson learned.
    Another thing you can try after doing what Tony suggests is to make sure there is no debris knocking thinks out of alignment.
    Lastly, those nylon washers everybody loves to tell you to use will cause runout.
    lutefisk capitol, USA
    485
    Another way to look at it is that you saved a lot of money on an eccentric chuck. Time for multi-axis turning.
    Aug 2008
    Reno, Nv
    3,632
    That sucks that you broke your chuck, Chuck.
    Oct 2008
    1,357
    Quote Originally Posted by Jim Burr View Post
    Happy hour at your house Jim??
    Aloha,
    Aug 2008
    Reno, Nv
    3,632
    Quote Originally Posted by Royall Clark View Post
    Nah...I'm at work out of town and needed a laugh.
  1. 12345
    By Chuck Thoits in forum Off Topic Discussion
    Last Post: 04-26-2009, 05:23 PM
  2. 12345
    By Chuck Thoits in forum Jigs and Fixtures
    Last Post: 03-05-2009, 11:31 PM
  3. 12345
    By Chuck Thoits in forum Turning Tool Questions and Show & Tell
    Last Post: 02-11-2009, 09:27 AM
  4. 12345
    Last Post: 02-03-2009, 02:05 AM
  5. 12345
    Last Post: 02-03-2009, 12:50 AM
