Results 1 to 9 of 9
Thread: Some Rockwell rebuilds
    May 2008
    Toronto, Ontario
    11
    I am new to the forum but I thought I would share some old iron I have rebuilt. Attached at a Rockwell unisaw, lathe that I converted to electronic variable speed and a disc/belt sander.
    Attached Thumbnails Attached Thumbnails DSC_0341.jpg   DSC_0162.jpg   DSC_0293.jpg
    Wow, all three look top-notch, Rick. What size of motor did you end up with in the lathe?
    May 2008
    Toronto, Ontario
    11
    I pulled out a 3/4 HP and replaced it with a 1HP motor.
    Bellingham
    2,450
    Looks really nice Rick. How did they look before you fixed them up?
    Oct 2008
    1,357
    Rick, what did the motor and control cost you? I've got a similar lathe and just curious.
    Nice job too!
    Aloha,
    May 2008
    Toronto, Ontario
    11
    I used a Marathon inverter duty motor 1HP 3PH that I purchased on ebay for $70 delivered. The drive I purchased from the following dealer 110v 1PH in and up to 1HP 3PH 220v to the motor
    http://dealerselectric.com/item.asp?cID=28&PID=428
    Than I added separate controls on the lathe with a pilot light, emergency stop, variable speed and forward/stop/reverse. The drive was installed in a 8"x8" metal enclosure with a primary on and off switch.
    Here are some pics of the lathe and sander prior to refurb and another shot of the sander with the same profile after the refurb.
    Attached Thumbnails Attached Thumbnails DSC_0146.JPG   DSCF2484.JPG   DSC_0288.JPG
    Jan 2009
    I live in Denton, Texas and ranched at Schulenburg, Texas.
    116
    Excellent work. Are those Rockler switches; if not what are they, and how do you like?
    Ray Gerdes
    May 2008
    Toronto, Ontario
    11
    Ray, the switches are not from Rockler although I am not sure which machine you are referring to
    hi rick!
    nice work!
  1. Plane rebuilds
    By Jim Burr in forum Neander Tool Questions and Show & Tell
    Last Post: 04-28-2011, 01:08 AM
  2. Rockwell Jawhorse
    By Robert Farmer in forum New Tools
    Last Post: 03-06-2011, 04:42 AM
  3. Rockwell 46-111 Bearings
    By Ron McClane in forum General Woodturning Q&A
    Last Post: 02-15-2010, 03:55 PM
  4. rockwell 28-200 bandsaw
    By Chris Mire in forum Old Iron
    Last Post: 07-01-2009, 12:59 AM
  5. Rockwell tools?
    By Matt Dunlap in forum General Woodworking Q&A
    Last Post: 11-30-2007, 12:31 AM
