Results 1 to 7 of 7
Thread: Legacy plane
    May 2008
    Toronto, Ontario
    11
    Legacy plane
    I decided to take a stab at building one of the 1" Legacy plane kits. It was definitely a learning experience. Overall I am pleased with how it turned out. The plane was ordered with Cocobolo for the infill but I ended up using rosewood instead. In hindsight I should have done less power sanding. For the final sanding I glued some sandpaper to a marble piece I use for sharpening. This took some time as the power sander was not as flat as I would have liked so it took some time to remove all the scratches and get a flat surface. I honed the blade and it produces some fine shavings.
    Attached Thumbnails Attached Thumbnails DSC_0370-1.JPG   DSC_0381.JPG   DSC_0384.JPG
    11,830
    I'm just a plain nut, not much of a plane nut type.
    But, that looks like an interesting project and a job well done.
    Who sells the Legacy plane kits?
    May 2008
    Toronto, Ontario
    11
    The company is going out of business but they may have some 3/4" kits left.
    http://legacyplanes.com/index.php
    30,014
    Wow, that's a sweet-looking plane. Great job.
    Bellingham
    2,449
    Really great looking shoulder plane. I have been following Jameel Abraham on his blog build a Brese 875 Smoother. http://oudluthier.blogspot.com/searc...l/Hand%20Tools It has me thinking of building Ron Brese's small smoother (which Jameel also built) later this year.
    www.breseplane.com/
    What did you find to be the most difficult aspect of building the infill shoulder plane?
    May 2008
    Toronto, Ontario
    11
    Thanks for the feedback. I would have to say the hardest part was the last stage...sanding. Now that I have gone through the process I would do less power sanding and more by hand. Power sanding did not leave as flat a surface as I originally thought. I ended up removing more material than necessary flattening all the surfaces. The peining processes was also interesting as you always questions as to whether the joints are tight enough.
    11,830
    Quote Originally Posted by Rick Beko View Post
    Impressive prices for a kit.
    I'll enjoy from a distance. Thanks.
  1. Legacy Ornamental Mill For Sale
    By Bill Grumbine in forum Old Ads
    Last Post: 04-24-2008, 02:54 PM
  2. Legacy or Ornamental Mills
    By Jonathan Shively in forum General Woodturning Q&A
    Last Post: 04-05-2008, 04:55 AM
  3. Added to the Johnson Legacy
    Last Post: 09-11-2007, 02:01 PM
  4. Legacy Mill
    By Allen Bookout in forum General Woodworking Q&A
    Last Post: 04-11-2007, 11:44 PM
  5. Legacy 1000EX
    By Dave Richards in forum Old Ads
    Last Post: 12-13-2006, 03:38 AM
