Results 1 to 10 of 15
Thread: Mission style dresser - latest design, please critique!
    Topeka KS
    118
    ok this is an original design inspired by the craftsman style. im not 100% finished with it as i havent decided on a what type of joints to use on a few pieces but its pretty much done. i would like opinions on overall design and whether it would "work" if i decided to build it in wood
    i had to zip the skp file as it was slightly larger then the 150 limit
    dresser.zip
    Als ik kan
    I like it but I might try brining the front stiles to the floor. something like this (but that's just me):
    30,017
    I know zippo about furniture design, but I really like what you've drawn, and I also like Glenn's suggestion of running the front stiles all the way to the floor.
    Topeka KS
    118
    thats one thing i was iffy about was the thickness of the legs. they are 1" thick but look kind of small. i like your suggestion about the stiles i will try that out and see what i can do. thanks!
    Als ik kan
    Geneseo, Illinois
    61
    I'm with Glenn on this one. Craftman style should look hefty. Nice design by the way
    Santa Rosa, CA
    138
    I also like Glenn's mod. To that I'd make the front stiles wider so the joint is on the side not the front. Sorry, I've got almost no SketchUp skills to illustrate the concept.
    Constantine, MI
    7,891
    Ditto on the mod. I like the way the sides splay out. Very interesting. Have you considered extending the ends of the top a bit and adding corbels?
    www.wrworkshop.com
    Dec 2008
    falcon heights, minnesota
    5,610
    here's my take on the dresser. i liked the idea of bringing the frame stiles to the floor, did that with the front board, and widened it out a bit, then narrowed the side frame boards a touch. i widened the top horizontally 2" on each side. no too sure about corbels though. that would be up to you.
    benedictione omnes bene
    www.burroviejowoodworking.com
    SE Minnesota
    2,526
    Nice but you might want to consider changing the sides. They'll be a real pain to clean.
    London, Ontario
    3,383
    Quote Originally Posted by Dave Richards View Post
    This.
    I had a look at the file in sketchup. While on the subject of the sides, I wonder about the top + bottom rails. I measured, and I see that they are the exact same height. However, with the curve on the bottom rail, it gives the impression of being narrower than the top rail. I noticed that pretty quickly. I would experiment with a narrower top rail to see what looks right. alternatively, I'd experiment with removing the curve in the bottom rail.
    Next around to the front... IMHO I find the rail above the top drawers to be on the thick side. I agree with the comments about extending the stiles to the floor. For one thing, as it stands the curve in the rail under the bottom drawer looks off, because it turns horizontal under the stile.
    I'm not especially fond of the way the sides flare out. But I do admit that it is a striking feature. It'd be a challenge to build.
    Keep posting. I love discussing designs.
    ...art
  1. Alternative design for Mission style Chairs
    By Don Baer in forum Designs, Plans and Sketches
    Last Post: 08-10-2009, 01:56 AM
  2. Mission Style End Table
    By Dave Haynes in forum Flatwork Project Showcase
    Last Post: 07-20-2009, 07:11 PM
  3. Mission Taboret - first sketchup model, please critique
    By Mike Gager in forum Designs, Plans and Sketches
    Last Post: 02-10-2009, 03:58 AM
  4. Mission Style Bench
    By scott spencer in forum Flatwork Project Showcase
    Last Post: 05-24-2008, 05:02 AM
  5. Glider Design - Critique Please
    Last Post: 05-25-2007, 02:14 AM
