Results 1 to 10 of 13
Thread: Is it worth turning??
    Oct 2008
    1,357
    I was taking to some friends over lunch when one of them mentioned one of the trees he's having taken down on his property was a rubber tree. It is about 100' tall and fairly big in the butt. I asked him if this it the same tree they get the latex from but he didn't know. He just said it had large waxy oval shaped green leaves. With so little information is it worth grabbing some for turning???
    I'll try to stop by and take some photos of it.
    Aloha,
    Aug 2008
    Reno, Nv
    3,632
    If it's free...it's worth turning. It may need to be stabilized and since I know nothing about rubber trees...my advice is crap. But try it anyway...could be a diamond in the rough or a pain the the same.
    Inside the Beltway
    2,666
    Royall,
    My guess is its a Ficus elastica, rather than a true rubber tree. If you had visions of it bouncing all over the shop, don't worry...
    It's actually a kind of fig tree, and might make for some interesting stuff. It's at least worth a try. I'd be interested to know how it met its demise...
    Bill
    I'm with the others...try it and see what you get. If it is indeed ficus, you might be in for a treat. I recall seeing pics of some turned ficus that looked real nice.
    Oct 2008
    1,357
    I guess I'll go over to Don's house tomorrow with the ol' chainsaw. I guess some of the chunks are almost 24". It's coming down to let some sunshine through the jungle. It is growing amongst a bunch of junk trees like albizia (not the brown). They can reach 60-80 feet and 2' plus at the butt in 10-15 years. The wood isn't even good for pulp for some reason and can be very dangerous as the limbs can for break and fall for little or no reason.
    If I get some, do I paint the ends?? will latex pain work.... hope so that's all I got
    By the way..... what length is a good size to cut the rounds???
    Aloha,
    Palm Springs, Ca
    1,169
    Yep try it and see what happens if it doesnt work out you can try stablizing it, and some fun trying to make it work. If nothing works you have some designer firewood for the cold times..............
    Tellico Plains, Tennessee
    4,353
    He lives in Hawaii!
    'course, the big island also has a ski resort and a volcano... can you say hot and cold
    Chuck
    Tellico Plains, TN
    Inside the Beltway
    2,666
    Quote Originally Posted by Royall Clark View Post
    Royall,
    What's the distance from the spindle to the lathe bed? On mine, it's nine inches. So I double that, and add two inches for slop, mistakes, and unanticipated yuckiness. Gives me 20", anything beyond that is just waste. Not that I can actually turn anything quite that big (my lathe doesn't go below 600 rpm, and an unbalanced blank at that speed would shake all over the place). I think the biggest bowl I've ever actually turned was about 16", and it was a bit too exciting for my taste...
    Bill
    Oct 2008
    1,357
    Stabilizing, is that when you put it in the DNA?
    Firewood?? I don't normally need heat here. I'm at about 135' elevation and anytime other than winter it is great! Don't have any way to heat the house. Best we can do if we can't stand it is run the oven cleaning cycle. By the time the cleaning cycle is finished it has warmed up outside. Right now it's 6:30 am and it's only 64* and I've got my warm sweat pant on, socks and house shoes, a tee shirt and a long sleeve Chamois shirt! 64* feels mighty cool when the old blood thins out!
    He lives in Hawaii!
    Almost got it Chuck They do ski up on Mouna Kea, but there's no resort. The snow doesn't get that deep or hang around that long. If you're at the snow level you'll be 13,000 plus feet and with no ski lifts you don't make too many runs before you're puking your guts out from altitude sickness sure sounds like fun!
    Royall,
    Bill
    Bill, from center to bed is 7" and I could mount a 36" spindle blank. It's an old Rockwell 46-111. I think is was Tod who asked awhile back what I wanted to turn and had to tell him I didn't have a clue! I'll figure that out as I learn.
    So, do I cut the rounds to 36" diameter and break them into chunks with an axe and BS. Or should I just cut up some limbs that are about 6-10" diameter?
    Aloha,
    Royall, the DNA is to speed up the drying. Stabilizing would be to coat the wood with something that soaks in and makes the wood fibers more stiff. There are a lot of ways to stabilize soft or spongy wood...thin shellac, CA glue, commercial wood hardeners, etc.
    At this stage in your turning experiences, I'd suggest cutting some of the branch wood into 24" to 30" lengths for spindle-type projects, and some of the bigger log sections into bowl blanks sized to fit your lathe's capacity (plus a bit for trimming). 16" x 16" x somewhere around 3" to 6" would be about the biggest, and you can always have smaller ones, too.
    Here are a couple references for some bowl blank cutting ideas...
    http://handturnedbowls.biz/data/how_to_saw_log.pdf
    http://www.nestlerode.org/Fun_with_C...ing_blanks.php
    And yeppers, you can use latex paint to seal the end grain. I'd suggest glopping on a couple thick coats, but it does work.
  1. Is this saw worth anything?
    By ed sautter in forum New Tools
    Last Post: 02-24-2012, 06:46 PM
  2. Is this worth a look?
    Last Post: 02-05-2011, 04:17 PM
  3. this is worth getting there for, I know the guy
    By allen levine in forum Hot Deals
    Last Post: 01-23-2010, 03:02 PM
  4. What is this, and it it worth $100.....?
    Last Post: 07-05-2009, 02:29 AM
  5. What's it worth, ?????
    By Robert Schaubhut in forum General Woodworking Q&A
    Last Post: 11-11-2007, 02:14 PM
