Results 1 to 6 of 6
Thread: Poly Urethane over Danish oil
    Sep 2008
    Pretoria, South Africa
    52
    I just finished Rosewood table to use in my Lapa, and fininshed it with Danish oil. I do however think that I did not hand sand it enough because it has dull spots where most of the top is fairly shiny.
    In the mean time I figured that a Poly Urethane finish would have provided more protection since it is a semi exposed environment. The sides of the Lapa is open and although we made a decent cover for the table, it is still "outside"
    My question is: would it work if I sand it down, and then apply a Poly coating with a spray gun? Would it bind to the Danish oil? How could I prepare it better for the Poly Coating?
    Uys
    _______________________________________
    Uys van Rooyen
    Uys is pronounced "Ace" - it's Dutch
    It should be no problem, I do it all the time, and I don't even sand the danish oil. Many like to use danish oil or boiled linseed oil first cause it tends to bring out the grain, then top coat with, poly, laquer, or whatever. I think it helps with making the top coat flow and cover more evenly.
    Just make sure it is DRY....
    30,008
    Quote Originally Posted by Bill Simpson View Post
    Yep...make sure the Danish Oil is fully cured before putting a clear coat over it. It may take a week or more, but after it's cured, you should be in good shape.
    Sep 2008
    52
    Thanks all.
    The oil's been on there for more than 3 weeks, I think it is dry
    I'll have to sand again, because I didn't do it enough during the first round.
    Uys van Rooyen
    Uys I think that it will better when you get the poly on it and its said that poly is better in the long run as far as protection anyway.......Marshall....
    Usually Busier than a Cat In A sand Box : Arkansas Red Wolf & Razorbacks Fan
  1. Urethane
    By ken lutes in forum Finishing School
    Last Post: 01-14-2015, 08:41 PM
  2. Danish Modern?
    Last Post: 07-14-2014, 05:37 PM
  3. Danish oil question
    By Jerry Strojny in forum Finishing School
    Last Post: 12-06-2011, 02:51 PM
  4. Urethane Euro Premium
    Last Post: 04-30-2009, 02:56 PM
  5. Urethane & polyeurethane ??
    By Drew Watson in forum Finishing School
    Last Post: 01-08-2008, 04:59 PM
