Ron Roase
- Bloomington MN USA
Some times it takes some of us longer than others to see the light. My compresser is up over head in my garage to save on floor space. I have a cieling pannel that I can remove, so as to get to my compresser for maintanence. I went up there to drain any condensation from the air tank. But the drain valve was frozen in a closed position. Tryed to remove it with no sucsess. I finally drilled it out and put a piece of air hose on it and ran it down to where I can reach it from the floor. Now its a simple matter to just hold a can under the shut off and drain the tank. I may later add more hose to bring it closer to the floor and then just leave a pail under it. This time I used a Ball type valve ,so less chance of any problems.
