Results 1 to 10 of 11
Thread: Threaded inserts for a Crib
    Indiana
    130
    I'm looking at some treaded inserts for a crib, I havent used any before, and was wondering if anyone had a recomendation on a glue to keep them in place to prevent them backing out some how, or is that just over kill.
    Rockler
    I'm probobly leaning to the brass ones. These will be put into poplar.
    I've used the brass and the hex drive. I have never had either try to back out or come loose; no glue required. I prefer the brass as the hex drive rounded out during install.
    Indiana
    130
    Aswome, and thanks for the info on the hex one, I noticed they have an install tool also so I might grab that. I think I have fallen in love with the rockler site.. first time i've come across it and I keep finding new stuff to add to the wish list
    5,319
    Quote Originally Posted by Chris Marlor View Post
    Aswome, and thanks for the info on the hex one, I noticed they have an install tool also so I might grab that...
    My preference is for the brass ones. Two tips:
    1. Lightly chamfer the edge of the mounting hole; and,
    2. Definitely use the installation tool. Trying to install them using a screwdriver invariably ends in either breaking out the slot in the insert, marring the surface of the wood, or both. DAMHIKT!
    Funny, your question about inserts made me get off my duff and add the bench stop I've been meaning to get to. Sometimes the 15 minute jobs get put soooo long.
    I use a bolt, nuts and a washer for the installation "tool".
    I start with a nut driver so I can get it straight.
    Finish with a wrench.
    Back the nuts off and remove the bolt.
    Use the hex key to give it a 1/4 turn to recess it just a bit.
    Here's what I'm using them for (this is just an example, it is not finished
ID:	29258 Click image for larger version.
    Oct 2008
    1,357
    Good idea! you might want to repost that in tips or jigs
    Aloha,
    5,319
    Glenn said: I use a bolt, nuts and a washer for the installation "tool".
    That's what I used for a long time, but a few years back, McFeeley's had a deal on the drivers that was too good to pass up, so I bought a couple. They're easier to use than the improvised bolt/nuts driver, but do essentially the same job.
    I put a 4-6" carriage bolt thru the top of a jig knob and run it all the way in. A hex nut from the other directions locks it in place. One more nut to secure the insert and Bob's your uncle.
    If you like Rockler, you'll LOVE Hartville Tool: http://www.hartvilletool.com/product/12304
    "Woodnet 15" gets you 15% off regular priced stuff.
    Bob Ross
    WALNUT ACRE WOODWORKING
    Ideas, Products & Accessories for Serious Safety-Minded Woodworkers
    www.walnutacrewoodworking.com
    Please Pray for Our Troops
    Semper Fi!!
    Vernon, WI
    230
    Chris I also used these, in poplar, and also to make a crib. I had some issues stripping out the hex head also, quite frustrating. No glue was necessary though, just drilled a hole deep enough to accept the whole insert and then it bottomed out
    5,319
    Quote Originally Posted by Westley Rosenbaum View Post
    ...used these, in poplar, and ...had some issues stripping out the hex head also, quite frustrating. ...
    Try using a bit of beeswax or paraffin wax on the threads. It makes insertion easier, and I've never had one back out, either.
  1. Redwood HF with Threaded Lid
    By Nate Davey in forum Lathe Project Showcase
    Last Post: 02-09-2014, 08:49 PM
  2. FREE Zero Clearance TS Inserts
    By Jim C Bradley in forum Giveaways, Contests, and Swaps
    Last Post: 04-04-2013, 10:27 PM
  3. Safety switch inserts
    By Jonathan Shively in forum General Woodworking Q&A
    Last Post: 09-28-2011, 10:49 AM
  4. So what do you guys pay for the glass inserts
    By Don Baer in forum General Woodturning Q&A
    Last Post: 11-05-2010, 12:12 PM
  5. Length of threaded end of a spindle.
    By Alfredo Alamo in forum Turning Tool Questions and Show & Tell
    Last Post: 02-23-2008, 02:48 PM
