Results 1 to 10 of 25
Thread: profile question, double bead
    17,470
    how would you make this profile
    on the curved shape i am showing
    here on the left side?
    the black shape is the profile i am after. this would be the top edge your looking at,,cross section
    http://www.woodline.com/p-1490-fluti...-14-shank.aspx
    and a sander for the slight radius on the top.
    17,470
    hey tod o got the raduis on top solved, its the bead that is givin me fits.. the bit you showed is going to make a flute and my next question is how do i follow the curve on the side of the side panel? i have a curved road and only 2" to ride on?
    4,551
    May just have to use a V chisel
    whoops.......use a standard fluting bit;
    http://www.woodline.com/p-1541-round...-12-shank.aspx
    you`ll have to build a 2 prong guide to follow the curves, i use pieces of drill rod, for your piece space them about 1-1/2"-2" appart.
    17,470
    well tod could you scratch out a pic of the jig your mentioneing i think i got the idea of the jig but the bit your showing this time is still gonna make a flute.. will try to take apic of my sample block to show you.. gone to picture takin
    here ya go larry.......you`ll need to do this in a router base the correct distance from your bit though.
    17,470
    profile pic
    here is a shot of the profile i am after tod
    17,470
    ok tod, how do i determine the spacing that you suggested? wont that be differnt for inside curves rather outside curves?
    slightly but short of a single point guide (that`ll rock) this is as good as it gets with a spinning cutter unless you build a pattern to use a guide bushing...actually that`s probably the way to go, use the corebox bit with a bushing and a pattern.
    to make the pattern flush route a piece of mdf then rabbit the mdf 1/2 thickness and flush cut to the rabbit, repeat until you have the desired reveal.
  1. A router and a triple bead
    Last Post: 11-19-2014, 05:15 AM
  2. Double, double toil and trouble, Fire burn, and caldron bubble
    Last Post: 02-05-2014, 03:21 PM
  3. bead or not?
    By larry merlau in forum Designs, Plans and Sketches
    Last Post: 01-01-2013, 04:41 AM
  4. Should I Add a Bead or V Groove...
    By Bill Satko in forum Neander Woodworking Q&A
    Last Post: 01-11-2012, 12:21 PM
  5. Profile question for all you spinny folks
    By Rich Soby in forum General Woodturning Q&A
    Last Post: 07-31-2011, 03:36 PM
