Results 1 to 8 of 8
Thread: Thanks Vaughn.....Marty, I like it!
    2,784
    I'm guessing this is one of Vaughn's tweaks to the site. When uploading pictures, you can now browse and select up to 10 and up load at once, instead of having to do each one individually. Nice change! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    Steve Clardy Guest
    Vaughn's a good tweaker
    Toronto, Ontario, CANADA
    2,332
    This is a feature that we acquired when Marty moved us to a new provider.
    Cheers, Frank
    Tokiwadai, Japan
    2,882
    The feature is built-into the vBulletin software FWW uses... one of the options you can select.
    29,079
    Yeah, Frank's right...Marty gets the credit for this one. I like it too.
    2,784
    Way to go Marty, then!!!
    Exclusively Irish!
    Southern Georgia
    1,396
    Folks,
    I probably should be punished instead of thanked. I really should have asked before I made the change. But something so simple, and (I believe) useful, seemed like something people wouldn't mind. And it sounds like I was right...
    Of course, I had selfish motives, given the volume of pictures I typically upload...
    Glad folks like it...
    - Marty -
    Fivebraids, Inc.
    When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there’s no end to what you can’t do…
    15,582
    I like it too, in fact another board, the Ozzy WW board has this function, and I like it, I meant to ask them how to tweak it, but I now see it is done.
  1. Maybe Marty Needs a Barbie Fishing Set?
    Last Post: 08-22-2008, 01:28 PM
  2. Marty's Projects?
    By Keith Starosta in forum Flatwork Project Showcase
    Last Post: 09-05-2007, 10:34 AM
  3. Marty Flore
    By Rennie Heuer in forum Welcome and Introductions
    Last Post: 01-11-2007, 11:27 PM
  4. as a thank-you to marty
    By tod evans in forum Off Topic Discussion
    Last Post: 12-25-2006, 07:40 PM
  5. HAPPY BIRTHDAY MARTY!
    Last Post: 12-02-2006, 12:51 PM
