Results 1 to 10 of 19
Thread: spring cleaning... & a Question
    5,533
    After my winter making cutting boards, I had a bit of sawdust warming the floor of the shop... I also was stuck with a very small aisle in which to walk around with my benches pulled out from the wall after insulating the one wall last fall. Well, now that things are slowly getting warmer, at least to where I'm not going to get frostbite I decided it was time to clean up.
    before:
    and after an hour or so of sorting moving and even installing a sheet of plywood behind the bench (horizontally, I'm putting pegboard above it) I had this:
    Still lots of clutter on the bench, but it is a relatively Organized clutter.
    That section of the reflectix above the benches is where I'll be putting the pegboard. Should I mount it directly to the studs ,or should I put up a couple of 3/4 thick boards to stand them off of the wall just a bit?
    Oh, and here's Why my shop is up on blocks instead of directly on grade:
    -Ned
    Constantine, MI
    7,891
    Soggy!
    www.wrworkshop.com
    5,533
    ayup, and it isn't just the standing water, the ground all the way around up to the house is squishy, those are just the low points.
    -Ned
    Oct 2008
    1,357
    Got hip boots?
    Aloha,
    new york city burbs
    10,188
    ned, first project of the warm weather, put in that top step dude!
    btw, I dont see anything wrong with the clutter as long as you can find what you need, then just push it all to one side to work, then push it back to the other side when you gotta do something else.
    17,474
    is there insul behind the reflector stuff? if so why have the reflector stuff on there? does the reflector add that much r value? other than that yu will need to have space for the pins to work the reflector may give enough for that part but will make the wall area wavy i would use furring strips.
    13,452
    Wow almost bought a house with a yard like that and basement too. Luckily we checked it out one more time just after a good rain spell. Anywhere to put a french drain in to drain to? Or are all the neighboring yards that flat?
    3,134
    Hark do I see a 10 year project sitting in a puddle of water?
    Ned it looks like you have all kinds of room in there you just have to find it.
    17,474
    no bart you spelt it wrong its ark not hark and its suypposed to float
    As to the pegboard stand off, I would. If you mount flat to the surface the pegs will dig into your pretty silver stuff.
  1. Spring Cleaning
    Last Post: 03-31-2015, 02:53 PM
  2. What do you use for every day cleaning?
    By Rennie Heuer in forum Finishing School
    Last Post: 10-24-2012, 03:01 PM
  3. Been Cleaning
    By Chuck Thoits in forum Shop Tours
    Last Post: 01-19-2010, 07:13 PM
  4. Cleaning, cleaning, thinning out.....
    By Douglas Jones in forum Old Ads
    Last Post: 06-24-2008, 09:59 PM
  5. Cleaning new tools question?
    By Joe Mioux in forum New Tools
    Last Post: 07-10-2007, 01:31 PM
